Results 1 to 6 of 6
Thread: Calculate LED Watts
    Feb 2004
    Calculate LED Watts
    I've got these SuperFlux LEDs from Lumileds. They have a forward voltage of 2.5V so I am stringing 4 of them in series. How do I calculate the total current and power?
    +12V ----|>------|>-----|>------|>-----GND
    Max current: 70ma
    Power dissipation: 221mW
    Forward voltage: 2.5V
    Top Ramen lgbr's Avatar
    Feb 2004
    Spokane, WA, US
    221 mW / 2.5V = 88.4 mA
    Audio Rockford Fosgate: 900 Watt 4-channel amp, 501bd Mono amp
    Computer AMD 2400+ XP, 1 GB DDR RAM, Orbit Micro 250W DC-DC PSU
    Head units are for cheaters!
    sure some girls fake orgasms.....but it's guys like me who fake the whole relationship
    FLAC Pudge's Avatar
    Sep 2003
    AZ
    But he has 4. So 353.6 mA. I think...
    My Carputer! (More Car Pics at the end)
    2 Kicker Comp 10"
    Epia M-9000, 256 MB DDR, 120 Gig HD
    Lilliput 7" VGA Touchscreen
    Check it out?!
    Feb 2004
    Thanks. A few more questions
    a) Assuming a 10V power supply, wouldn't it be 0.175W per LED ( P = IV = 70mA * 2.5V)?
    d) When analyzing circuits can I treat LEDs as a resistor?
    b) Do LEDs have a series resistor in them?
    c) In this case equal to 35 ohm (R = V/I = 2.5V/0.07A)?
    d) These have a min and max flux rating. Is a higher flux achieved by running a higher forward voltage?
    Thanks again!
    May 2004
    Quote Originally Posted by bambooracer
    Max current: 70ma
    For practical purposes, a good, working LED has no resistance, it does however, produce a voltage drop.
    The circuit as drawn is only going to blow LEDs. Given the whole V = I * R thing, and that LEDs have almost no R, to calculate the current flowing in the LEDs is I = V / R. As R gets really small, I gets really big. Since the max. current for these things is small (70mA) you'll fry them before you see them light up.
    To fix this you need a resistor.
    12V is the source, and each LED drops 2.5V so 12 - 2.5 -2.5 -2.5 -2.5 = 2V. 2V is the remaining pressure you have to drop, and you want to draw less than 70mA doing it. Again V = I * R. This time you want R, so R = V / I = 2 / 0.070 = 28 Ohms. You wont find a 28 Ohm resistor, so get the next biggest size, probably a 30.
    Power is calculated for this circuit with P = V * I.
    A 28 Ohm resister would give you 70mA through each LED, but your using a different one, so you need to calculate the actual current. V = I * R (seeing a pattern yet?) I = V / R = 2/30 = 0.066 = 66mA.
    Power for each LED is V*I = 2.5 * 0.066 = 0.165W = 165mW. And there are four of them: 4 * 165mW = 660mW. Don't forget the energy being dissapated by the resister at 2V * 66mA = 132mW. So the whole thing is eating up 660 + 132 = 792mW.
    Constant Bitrate gubon13's Avatar
    Los Angeles
    Dammit Sparc, good post. I wanted to sound all nerdy, but it looks like you beat me to it... =b
    "Is Wayne Brady gonna have to choke a b@$#*??!!"
  1. Powermate LED
    By G35Pimp in forum Input Devices
    Last Post: 04-01-2005, 12:51 AM
  2. LED wiring question....
    By jusatry in forum General Hardware Discussion
    Last Post: 03-29-2004, 10:31 PM
  3. LCD to LED or LED meters.
    By silvertoy in forum LCD/Display
    Last Post: 02-17-2003, 11:07 PM
  4. Reset / HDD activity LED
    By JohnB1182 in forum General Hardware Discussion
    Last Post: 07-10-2002, 02:48 PM
  5. simple LED circuit.. did i do this right?
    By ShinkunoNamida in forum Off Topic
    Last Post: 06-04-2002, 12:23 AM
