Results 1 to 10 of 11
Thread: Towing a car on a flatbed trailer
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    Alright, here's the deal. I need to tow my car about 1000 miles in a week. I have a trailer, but it is not specifically designed for a car, just a flatbed trailer. It has siderails on it. I need to know how I should secure the car to trailer. Problem is, my car only has 1 tie down point on the left-rear of the car and I cannot drill any holes into the floor of the trailer. Only securing points are the rails along the sides. Any ideas?
    FLAC Chairboy's Avatar
    Jan 2004
    Maybe... in-gear, parking brake set, and use the tie down in the back as well as tying a nylon strap to the tow hook on the front of the car and then to the neck of the trailer?
    Jun 2003
    Fairfax, VA
    I dont think there is a tow hook in the front of the car, that is my dilemma...
    Jan 2003
    Ruston, LA
    There are all kinds of places to tie any car down. Axels, make a net over the wheels, etc.
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    Run a strap through the forward frame members or lower control arms, then to the towing neck (the bar that runs up to the towing vehicle). You won't have to worry about too much torque on them, so little risk of damage. Plus, running it through both of them distributes any potential load. For the rear, depending on the type of body the car has, use the rear axle, up against the wheels, or the rear bumper support struts. Use both sides individually if possible, and if the side railing is sturdy enough, tie to them.
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
    Elsewhere
    Quote Originally Posted by binary.h4x
    I've read the thread. No tow hooks.
    Wrapping tow straps around the control arms is a good suggestion since you have no tow hooks.. You'll need four tow straps, one for each wheel.
    You want to ratchet the tow straps so that the suspension is compressed about halfway. The springs pushing up against the towstrap that's pulling the car down will help to keep it immobilized.
    I'd cross the tow straps at one end of the vehicle if you can, as well to help prevent lateral movement.
    Drive sanely with the car on the flatbed, and you'll be fine (so long as everyone else isn't driving like a bloody idiot).
    How about the Wiki?
    Jun 2003
    Fairfax, VA
    Thanks for the responses guys, I had been contimplating the control arms and/or axels. Looks like that is what i'll be doing.
    Jan 2001
    the best way to tie a car to a trailer is from the axles.
    be sure to drive slower than you normally would. (esp if the trailer you're using doesn't have brakes)
    Nov 2003
    Detroit MI
    Quote Originally Posted by bgoodman
    Yeah, what he said. That damned pesky "inertia" thing and whatnot.
    The ALEXIS Project
    Color Coding :
    Jan 2001
    well, say a 1500lb trailer with a 3500-4000lb car on it (not sure about the weight of the car in question here) you're looking at 5000lbs plus 4000-5000 more from the truck pulling it you're at 10000 gross. Not much fun if you're not familar with towing. Probably best to keep it around 55 for the sake of gas consumption as well.
    Also be sure to check and re-tighten your tiedowns every few hours. You also probably should use Tie-downs rated at far more than the car weighs.
  1. What's your dream car?
    By Aaron Cake in forum Off Topic
    Last Post: 10-02-2007, 07:34 AM
  2. Replies: 9
    Last Post: 06-08-2006, 05:15 PM
  3. FS: Car Computer Setup - Everything you need!! Pics Galore
    By EBoundEE in forum Classified Archive
    Last Post: 06-19-2004, 09:41 PM
  4. The melbourne car show
    By magnetik in forum General MP3Car Discussion
    Last Post: 03-13-2002, 05:05 PM
