They change depending on number of posts, so as you get more posts, your "bitrate" will go up.
Garry
What does the low bitrate mean under Avatar.
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
More specifically... bitrate is a measure of how many bits are used to store musical information over a given period of time. For example a bit rate of 128kbps means that one second of audio will consume 128,000 bits of storage. Higher bit rates have better sound quality.
So... the admins have decided to use the sound quality standards to label the users based on how many posts they have. For instance, Confused is labeled FLAC. That's a compression that is virtually lossless, meaning the decompressed sound has as much information as the compressed sound.
Hope that's more information than you wanted ;-)
Actually, completely lossless, it can be decompressed to the original waveform exactly. It's basically a zip file with compression that is tuned for waveform data.Originally Posted by Adam432823
[H]4 Life
I'm a lesbian too.
I am for hire!
/me posts here to find what my bitrate is lol
your expedition only has 255 hp? my 98 explorer has 220???
In other words - he spends more time posting here than breathingOriginally Posted by Adam432823
Terran
Didn't realise I was now variable - woohoo!
Slowly but surely....
Bitrate check![]()
2011 Nissan Frontier SL
AMD X3 2.2 | M4-ATX | 16Gb SSD | 2GB DDR3-1333 | MSI GF615M-P33 MB
OBDPROS USB | BU-303 GPS l LILLIPUT TS | Car2PC adapter | XM Direct | USB Dual band N with custom mag-mount antenna.
It wasn't blaringly obvious to you after two minutes of browsing the forum?
Well, don't worry. It's only a metaphor for your abilities to perceive and abstract qualities pre-existing in reality and to form concepts upon which you base your metaphysical value-judgements.
