Results 1 to 10 of 12
Thread: I need to vent a bit...Micro$haft....
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    So, my Micro$haft XP has been driving me up the wall and I need to vent a bit. Heres the deal. I have about 800 files on a hard drive (removable) and I want to transfer them to my pc. Drag and drop, copy and paste, and "send to" all fail stating that a file cannot be tranferred. Each time it stops at a different folder. Anyway, heres my gripe. Just because it cant transfer ONE file, it gives up? WTF! So now I am transferring them, 5 at a time. I also just love how it asks you if you really want to transfer a file, and HANGS until you answer. Why cant it work AROUND that file and proceed to others! Frodo needs to start developing his own O/S. I bet it would rock
    2005 Ford Focus ST
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Yeah, that always bugged me. It should copy the ones it can, and notify you of the ones it couldn't. I wonder if there's a utility (or ideally, shell extension) that does that.
    Variable Bitrate wkolodny's Avatar
    DC
    Quote Originally Posted by gospeed.racer
    Try this free program:
    http://www.2brightsparks.com/syncback/
    Don't Fear The Gurkey
    Click here to check out My Setup
    Oct 2004
    I knew there was something like that....
    The only real problem I have with Xp is that the goddamn thing restarts AUTOMATICALLY to update. Do you have ANY idea how much it sucks to lose your place in a porn, lose your place in a bunch of stories, AND lose your place in several forums?
    Constant Bitrate Big Zack's Avatar
    Oct 2003
    Quote Originally Posted by yalborap
    Lose your place in porn? What, is it restarting every 2 miutes?
    You know that's a setting you can adjust, right?
    ... and if that's the only "real problem" you have with XP consider yourself very lucky!
    - Z
    Oct 2004
    Well, the only noteworthy problem. I get the occasional annoying bit but it's not worth complaining about.
    And I'm good at watching an entire porn and enjoy the longer hentai stuff. Got a problem with that?
    Dec 2003
    Portland, OR
    Quote Originally Posted by wkolodny
    Sweet...i will check it out. Seems like the solution for XP is pretty much always 3rd party stuff.
    2005 Ford Focus ST
    Jan 2001
    you guys and your porn
    Maximum Bitrate deadweasel's Avatar
    Nov 2003
    Detroit MI
    The halting during copying is a big gripe of mine too. The problem is the filesystem that MS "developed" (FAT/NTFS). The whole thing is actively managed by one big table.
    The way to fix this would be to use a journaling filesystem, like what Unix/Linux are currently using. Those filesystems store file info in an actual database, and each file is independent of the master table. This means that interrupted move/copy operations resume on errors and such.
    The biggest gripe I currently have with MS? This very same journaling filesystem concept was being integrated into Longhorn, along with some other nifty system management tools and structures, that would have really made it worthwhile to use Winders. MS was calling it (you guessed it) MSFS. However, in the midst of all this waffling about the actual release date, MS, in their self-apparent wisdom, has pulled EVERYTHING of value out of the OS. Longhorn now looks to be nothing more than a bloated XP version. We will still all have to deal with the stupid "Are you sure you want to copy this text file from here to there?" prompts. It would be nice if we could disable those stupid verifications like we can with the Recycle Bin notification.
    /What the hell do you think I right-click-dragged that folder there for if I wasn't sure about copying it, idiot?!?!
    The ALEXIS Project
    MP3---VIDEO---GPS---REARVIEW---OBD---SKINNING
    Color Coding :
    DONE / MOSTLY DONE / BASE FEATURES / WORKING CONCEPT / NO CODE COMPLETED
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    NTFS is a journaling file system though the current version does not log enough information to reverse changes (http://www.backupbook.com/03Freezes_...ournaling.html).
    In any case, the hangs up when using the GUI copy have nothing to do with NFTS' lack of full journaling support. There are two likely causes of the copy failure. Either the file in question is in use (with an exclusive lock) and thus cannot be copied, or the copying application (the windows desktop shell in this case) is unable to deal with some abornormal conditions. In the case of external media, a device driver failure is another possibility.
    Here is a reference to a set of procedures you can follow to make sure that your files are not (inadvertantly) in use. http://www.softwarepatch.com/tips/howto-delete-xp.html
  1. Reducing my boot time bit by bit.
    By themurph1018 in forum General Hardware Discussion
    Last Post: 11-16-2004, 07:39 AM
  2. WTB: (or trade) 8" 18 bit touchscreen
    By SuperMatty in forum Classified Archive
    Last Post: 04-11-2003, 12:08 PM
  3. Sproggy psu a bit cheaper & easier
    By TDMP3 in forum Power Supplies
    Last Post: 08-04-2002, 02:29 AM
  4. 20 bit = high color or 256 ??
    By hippie in forum LCD/Display
    Last Post: 05-08-2001, 10:12 AM
  5. hiding ir receiver in air vent
    By grandamp3 in forum General Hardware Discussion
    Last Post: 11-17-2000, 01:12 PM
