Results 1 to 10 of 17
Thread: programming ...
    Constant Bitrate sagekoala's Avatar
    Aug 2004
    Des Moines, Iowa
    programming ...
    who wants to do my programming while i watch futurama? http://www.cs.iastate.edu/~cs227/Assign/hw8/hw8.html
    don't worry i know i usually don't make much sense
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    i do!
    '98 Explorer Sport
    80% done
    Jul 2004
    Ohio
    Sounds like fun... but I don't have my compiler anymore.
    Aug 2004
    Des Moines, Iowa
    i know!!
    Quote Originally Posted by LowMileLude
    you can still write it, just trace everything each time you change something! i need to start a contest ... every week we will see who can come up with the best solution to that weeks problem ... and the winner gets ... a golf ball or a stick of gum!
    May 2002
    Albany, NY
    heh.. i remember my old CS days.. out of 120 going in freshman year.. i graduated with 6 the freshman year CS courses about 10 people did the work and the others just copied
    Its no wonder why all programming jobs are getting outsourced
    g/l with your homework.. that wasn't meant to say you are looking for an easy way out.. just an observation on the laziness that is americans
    '98 Explorer Sport
    80% done
    Aug 2004
    Des Moines, Iowa
    yeah i don't live on campus (about 35 miles away actually) so i don't really get in on the copying. ... whats worse is that i should even have to take the course ... i got a 5 on both the compsci A and AB advanced placement tests but because they switched the tests over to java they won't transfer in the credit ... oh well
    Aug 2003
    Michigan
    oh how i miss those introductory computer science classes.
    if i remember right all of our tests were open book.
    VIA EPIA 533 MHz
    256 MB RAM
    7" Lilliput VGA Touchscreen
    20 gig HD
    Media Engine 2.1.4
    GPS - Earthmate/SA2004
    802.11b Connectivity
    Aug 2004
    Des Moines, Iowa
    lol wtf?
    all of our tests are pencil and paper, closed book, closed friend, and they pretty much have us write a program similar to that of the assigments. you can take all the time in the world ... they provide all the paper in the world for tracing. overall you always come out of the test feeling like you have been assraped because you know that they dock 10% for **** like an off by one error.
    p.s. it just occured to me ... WHY THE **** DIDN'T I TEST OUT?
    Maximum Bitrate smashr2k's Avatar
    Jun 2000
    Virginia
    they dont seem to care how long it takes to execute, so just use a two dimensional vector. to find a syn for a word, iterate through the first dimension of the vector. the synanyms will be contained in a list in the second dimension. if you get to the end there is no synanym. to add a synanym for a word, first check to see if you have the word in the first dimension, if you do add it to the end of that words list. if you do not resize the vector and add it to the bottom.
    if it had to be fast or large, i would reccomend using a hash table.
    Car: 1999 Dark Green Mustang GT Coupe
    Audio: Alpine HU, JL 6ch Amp, JL Stealthbox and XR series components.
    Player: Empeg for now; something custom later.
    www.neotechpc.com - Custom built laptops!
    Jul 2004
    Ohio
    Quote Originally Posted by sagekoala
    Yeah, I used to write code in notepad then email/copy/paste to compiler when I got home or to school. Real easy for C, not so easy for my Fortran compiler though (did all that on paper).
    As for cheating/copying... it was hard doing it. Our Prof. required us to make all our own unique variable names and notate each important line with what we are doing and why.
    I did rewrite major parts of my roomate's 77/90 code when we had the class together. He wasn't understanding the logic. I pretty much wrote two completely different codes, that made the same solution (mine and his). It might take 8 days to write it the first time but after that... might only take ~4 hours (since you already know the expected flow/outcome). I still think the Prof knew what I had done. But since it was so completely different and had my roomate's variable names and notations (made him make a list of variables then go through and read the sections and notate accordingly) he couldn't do anything other than let me help answer questions during lab time.
  1. Wanting to learn some programming, help me pick a language!
    By RS3RS in forum Software & Software Development
    Last Post: 10-15-2004, 05:38 PM
  2. C++: GUI Programming with >NET Framework
    By [iG] in forum Software & Software Development
    Last Post: 05-24-2004, 07:57 PM
  3. Programming IrMan in ME
    By RaZor in forum Media Engine
    Last Post: 03-29-2004, 03:49 AM
  4. batch file programming LCD's
    By mosh in forum LCD/Display
    Last Post: 05-19-2002, 01:55 AM
  5. Need to start somewhere with Hardware programming
    By 168db in forum Software & Software Development
    Last Post: 01-11-2002, 09:35 AM
