Results 1 to 6 of 6
Thread: Computer Problem; Cant see any icons in systray
    Aug 2002
    I cant see any icons in my systray. I see nothing. Programs are running and should appear there. What should I do?
    Jul 2004
    Ohio
    What OS? Are you running default settings or custom?
    Aug 2002
    Im using xp pro. No special settings.
    Maximum Bitrate Danceheaven's Avatar
    May 2002
    Essex, UK'er
    Sounds weird , does a reboot not sort it out in anyway?
    apart from that are you sure that the programs that are running are those that should appear as icons in the tray? check you registry to see how many applications are set to load on startup aswell
    Co Develper of A.I.M.E.E Automotive Intelligent Multimedia Entertainment Engine
    www.aimee.cc
    Aug 2002
    Reboot doesnt help. Im positive things should be in my systray. When I minimize AIM, it should show up in the systray but it doesnt. However it is still running.
    Newbie xelz's Avatar
    Loma Linda, Ca
    well if you have tweak ui installed, there's an option in there somewhere that enables/diables these systray icons. you need a reboot to make it take effect..
    if you don't have tweak ui installed, then no clue... did they just suddenly disappear?
  1. OPUS PSU Problem
    By WhateverJames in forum Power Supplies
    Last Post: 02-26-2006, 06:36 PM
  2. WIERD ps problem
    By Slitha in forum Power Supplies
    Last Post: 09-14-2004, 09:57 PM
  3. computer remote control
    By agent_86 in forum General Hardware Discussion
    Last Post: 10-18-2002, 03:36 PM
  4. computer remote control
    Last Post: 10-18-2002, 10:30 AM
  5. bump = reboot problem SOLVED
    By acitrano in forum General Hardware Discussion
    Last Post: 04-17-2001, 10:37 AM
