Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: Using 2 HD's to run pc, to boot
  1. #11
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Thanks, I like Scouse's key idea too. I only wouldn't want the key turned until it was shut down correctly.
    Maybe I should just get another pc
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
  2. #12
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Or you could use an OS selector software such as System Commander, which will also let you password protect "your" WinXP installation so your kid can't "accidentally" boot to it..
  3. #13
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    I saw a unit at Frys once that had 3 or 4 buttons on the front, and each was mated to a hard drive. You choose one, and turn on the system. Cant seem to find it anywhere to show you.
    Alternately, pretty much as said above...if you took 2 of the hard drive swap units, and hooked them both up as cable select....give yourself one key and your son the other. When one is "locked" it turns on, and the other is still off (and able to be undocked). It would seem to be very simple, cheap, and unless you get 2 keyed alike, foolproof.
    2005 Ford Focus ST
  4. #14
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by muldrick
    yeah i was thinking why not jsut get yourself a new Uber-computer
    Or you could modify the switch circuit by adding a multipole relay controlled by the switch.
    Switch in KID position - your kids drive has power.
    Switch in DAD position - relay switches over to power your drive and ALSO powers itself. That way even if your turn the switch to KID position when the PC is on the relay won't flick over until the ATX PSU has shut down. Easy as pie!
    Relay needs to switch Red, Yellow and itself in a parallel coil power supply (parallel in respect to the DAD/KID switch)
  5. #15
    Constant Bitrate old_lou's Avatar
    Oct 2004
    UK Midlands
    Quote Originally Posted by Scouse Monkey
    Something like this?
    leaving out the second switch makes it as Scouse recomends
    EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
    Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
  6. #16
    Aug 2004
    Houston
    perfect excuse to go out and build another PC!
  1. Replies: 30
    Last Post: 12-03-2004, 11:55 PM
  2. PC for sale
    By bluemagic in forum Classified Archive
    Last Post: 10-20-2004, 08:04 PM
  3. Pc wont boot with new pw-70a, Any ideas?
    By chriswhittleuk in forum Power Supplies
    Last Post: 06-22-2004, 07:33 PM
  4. PC car questions... please help.
    By euclide in forum Car Audio
    Last Post: 05-25-2004, 05:51 AM
  5. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
