on some new M.boards you can choose the booting device in the boot screen. If your worried about your child trashing the pc why not put a removable caddy in then only one disk at a time is in the machine? and he/she can't even get to your drive
I have 1 desktop pc, I want to use 2 harddrives, each with WinXP on them. (1 for me and 1 for my kid)
Can I set up the BIOS to ask me which HD to boot from?
I want my stuff to be completely seperate, kind of like having 2 pc's. Is this possible? How?
AtmosUSA.biz, E-Cig Mods
"A great smoking alternative"
EPIA MII: 512m Ram: LinITX 8" Touch Screen: Carnetix P1290 PSU: 802b PCMCIA Wireless card: Slot DVD Player: Touchpad: Wireless Keyboard: BU303 GPS Mouse:
Win 2000: RoadRunner Front End: Michelin Mapstore GPS: Netstumbler:
I know that in my extremely limited playing with Linux, with certain distros you can boot into Windows or Linux, and a loader makes you make the decision before you boot. I don't know if its possible to do it on an entirely Windows system though. And for the life of me, I can't remember the name of the loader that is used.
2000 Subaru OBS
Dell P3 @ 900 Mhz
7" Lilliput TS w/DigitalWW in-dash mount
80GB External HD
I am Zero Bitrate....
If you install two copies of XP one on each drive windows will automoatically bring up its own boot loader right after post and ask which OS you want to boot with. Files under user profiles will not be avilible to the other OS's users unless you go through alot of effor t to set it up that way.
My Install
Software:
CFiG v1
iGuidance Plugin for CF
CarShell
Working shell for a CarPC
StopWatch
StopWatch plugin remade for centrafuse RC1
actually if you install windows XP onto the first drive then install it again on the 2nd drive it should put both entries into the boot.ini so then when you start the computer it will give you a screen asking you which install you want to boot to. then you could just name them you and your kid. so then you would have two seperate copies of windows. Or you could just go with something like Bootmagic which does the same thing as lilo. just no linux involved.
肚子笑痛了
S60 Install
I like this answer the bestOriginally Posted by jcdillin
I'm now using the 1st drive. So I could: open the pc, disconnect this current drive, hook up the other drive, install XP. Then hook up both drives, then when it boots it'll ask me what drive to use?
Not exactly.Originally Posted by muldrick
Install XP on drive one. Then install it on drive two.
Leave them both connected.
[H]4 Life
I'm a lesbian too.
I am for hire!
yeah frodo is correct, you could try taking the current drive that has windows installed on it and install it as a secondary drive then install the 2nd blank drive as primary then just install windows on the blank drive and see if it gives you both options in boot.ini
肚子笑痛了
S60 Install
You clould jsut have both in the PC but put a key switch on that switches power between the two drives. that way when your kid uses it your drive is not even turned on so can't come to any harm and to use your drive you just put the key in and switch power to the drives. could do it with 2 caddies and turn one off but they are ugly.
