Originally Posted by
ChaCha
Okay. Do you see the inherent flaw in your statement. There is a very good reason why you can't get financed and that is because lenders do not believe you can EASILY afford a $35K car on your current salary. Neither do I, by the way. At least not yet. I'm not trying to bring you down but to offer you some good advice...if you want it.
Building up credit takes years. YEARS! It doesn't happen overnight. You need to establish lines of credit (credit cards, mortgages, loans, revolving lines of credit, etc.) then you have to use those lines of credit, then you will be evaluated on how you managed the credit.
You mentioned you don't have any credit cards. I suggest you get a credit card immediately and start using it. Shop around and get a card with a great rate. Then use it a lot. But don't max it out or even get near your limit. And the most important advice anyone can ever give you re: credit cards is only charge what you can afford to pay off each month. The credit card company of course would prefer that you charge you card up to the limit, that you can't pay the entire balance off, that you can only make your minimum required payments so they can squeeze 5-30% in interest out of you over years. Your credit score will also increase from this type of usage, however it will cost you a lot more in the long run. A LOT more.
You may be bummed about it, but not being able to put that financial noose around your neck (in the form of a new car loan) was a HUGE blessing in disguise. I'm happy that you decided to buy a used vehicle instead. A much smarter choice based on where you're at in life. Congratulations!
