Results 1 to 9 of 9
Thread: Whats this tool called?
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Ive been trying to get my stering dampener off but the bolt is rusted in and i need to get a tip to use with my air hammer but i dont knwo whats its called, Its like a U chaped wedge that will go around the bolt and pull it out. any ideas what its called and where i can get it?
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    FLAC djmickyg's Avatar
    Feb 2004
    is the nut rounded?? or just heavly rusted??
    get some WD40 (thin oil) into it and let it soak.. then ram it off with an impact driver..
    i know what tool ur talking about but i dont know the name either sorry. al i can think that is like that is a tie rod seperator. but that wont go into no gun
    Actually thats it! this one i just found a image will work with the air hammer but maybe ill just get a cheap standard one and beat it with a hammer. i dont know if its rusted at all its just seezed up in their and i have a 1/4"+ gap to get the tool under it.
    1990 Jeep Cherokee
    FLA gospeed.racer's Avatar
    Dec 2003
    Portland, OR
    In the industry it is often called a "pickle fork" as well. Just in case your searching. here is another pic
    2005 Ford Focus ST
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    Nut buster works wonders!
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    you could try a nut splitter but be careful you don't wreck your threads. Also try a 12 pointed socket not the usual hex ones and get a decent profesional qulaity one - decent tools are amazing compared to cheap ****.
    Mar 2004
    Bristol
    Quote Originally Posted by WebDog
    That looks like a ball joint separator. thos ehtings **** the rubber shields on ball joints if you are not careful.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Target practice?
    i got the tie rod seperator ($9.99) and it poped it right off
    The car drives so much better now, i also tightend the AC belt since it screamed some times haha...
    Good thing i was not removing a ball joint, Metal - Metal is what i had and it would not have matterd since i was replaceing the bolts.
    1990 Jeep Cherokee
  1. Replies: 2
    Last Post: 02-15-2005, 07:31 PM
  2. ColdHeat Soldering Tool!
    By [iG] in forum General Hardware Discussion
    Last Post: 02-04-2005, 09:11 PM
  3. Replies: 0
    Last Post: 12-05-2004, 09:00 PM
  4. PhoneControl XML files editing tool
    By zorro in forum PhoneControl
    Last Post: 10-17-2004, 07:25 AM
  5. best OBD tool
    By skassama in forum Engine Management, OBD-II, Engine Diagnostics, etc.
    Last Post: 01-07-2004, 11:13 AM
