Have you ever been able to see the full 80GB? What O/S are you running?
I've deleted all the partitions of my 80GB hard drive and put NTFS on it. But it still reads only 32GB. Is there any way to recover the rest of the drive?
Some drives have a capacity restriction jumper where the master/slave jumper is. That jumper makes the drive show 32GB in order to be compatible with older systems. Maybe it is shorted ?
run fdisk see if there are any unmounted volumes on that drive, any unpartitioned space?
www.streetrace.co.uk - The UK's best modified car club (With lots of 16/17/18 year olds for scouse to abuse)
The jumper was set to master so I switched it to cord select and it now recognizes it! Thanks Seth!
I don't understand why it wouldn't work on master. It must've at some point in time. I can't remember the last time I used it.
