Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: Removing glue from dash
    MySQL Error jcdillin's Avatar
    May 2003
    Miami, FL
    Well as most of you know I took the aftermarket dash kit off of my car, which went really well with the exception of screwing up 2 peices which only come to a total of $50 from the volvo dealer.
    but now in some places some of the glue from the double sided sticky tape is still stuck the dash
    anyone know of anything that will safely take that glue off? I dont want to use something like goo gone or goof off because I know it will ruin the dash. (I tested it on a old piece of dash that I had and it turned it into putty)
    any ideas?
    肚子笑痛了
    S60 Install
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    I had the same problem. I used some mineral spirits but still needed to paint it as it was discolored, if your a masochist, you could use this for the motivation to paint your dash.
    Bit of a PITA. This was before I had a spare one. I ended up doing it several times trying to get it flawless. I was driving around with my gauges wiretired to the cross support for months and an afghan, covering the mess.
    Finallly I said good enough and put it back in.
    May 2003
    Miami, FL
    ouch, yeah I was trying to get around repainting all the parts
    肚子笑痛了
    S60 Install
    Apr 2005
    Boston, MA
    Quote Originally Posted by jcdillin
    Maybe dampen it with a sponge and some soapy water, then a hair dryer to heat and loosen it?
    Actually, when I first botched my trim kit, I tried peanut butter. I've read this a bunch of places. It worked ok, but not good enough. I will advise against alchohol. The seller told me I should use it to prep my dash. My floor console got dull and soft. I could run my nail through it and leave a mark. It did firm up again but the finish was ruined. Sort of started me down the whole long painting road.
    May 2003
    Miami, FL
    yeah I think I am going to try some soapy water and see if that helps, i'm lucky most of the glue came off, so it's only in a few spots
    肚子笑痛了
    S60 Install
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    i dont see why mineral spirits wont work i use that on everything and goo gone or goof off i think its called
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    use some of that orange spray - it is very good for getting glue off. Or just save money and use some citric acid from a couple of oranges! That is all it is. Jsut test it somehwere 1st (see how it dries especially). But 1st try soapy water.
    May 2003
    Miami, FL
    Quote Originally Posted by jjh221
    肚子笑痛了
    S60 Install
    May 2003
    Miami, FL
    Quote Originally Posted by Scouse Monkey
    yeah I will try that
    肚子笑痛了
    S60 Install
    Dec 2003
    not sure yet.
    lol ok kick me i was lazy
    I GIVE FREE HUGS!
    Buy Sell or Trade
    Thank you
    Forex
  1. Replies: 39
    Last Post: 08-12-2007, 01:05 PM
  2. removing super glue fog
    By CavityCr33p in forum Fabrication
    Last Post: 04-11-2005, 12:45 AM
  3. In dash or Not in dash that is the question
    By belezeebub in forum Fabrication
    Last Post: 12-10-2004, 06:18 PM
  4. Removing super glue and bondo.
    By nappyjim in forum General MP3Car Discussion
    Last Post: 10-30-2004, 06:36 PM
  5. How to glue stuff in dash?
    By SuperMatty in forum LCD/Display
    Last Post: 10-13-2002, 05:28 PM
