Results 1 to 10 of 13
Thread: Very Wierd Computer Problem
    Maximum Bitrate XxAndyxX's Avatar
    Dec 2003
    Edmond, Oklahoma
    I've seen hundreds of different computer problems but this one is a first for me...
    When I try to start the computer, the fans will spin and that's it, no beeps or picture on the screen. I will turn my computer off and when I turn it back on it's fine, the mobo beeps and the computer boots into windows. If I turn it off and attempt to start it again, the fans will spin but nothing else. So it's like exactly the same way each time, it will work, next time it won't, next it will, and so on... I know it's either the motherboard or CPU.
    Has anyone ever had this problem before, and more importantly, have you found the reasoning behind it?
    Nov 2003
    bad powersupply most likely
    Dec 2003
    Edmond, Oklahoma
    Quote Originally Posted by Hcomplyr
    Nope, already tested it with another PS that I knew worked.
    Dec 2003
    Edmond, Oklahoma
    Things I've tried:
    Replaced power supply
    Replaced video card (tried a AGP and PCI card)
    Replaced RAM
    Reset BIOS (took out CMOS battery)
    Underclocking CPU
    Looks like it needs a new motherboard
    Constant Bitrate markopolo311's Avatar
    Apr 2005
    Atl GA
    sounds like a problem i had.......and yes, i did end up with a new mobo
    I'mmmmmm a n00b.... feel free to make fun
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    I have a friend with the same problem. I think he has an abit or an asus motherboard. Could just be a motherboard bug.
    Newbie DrumBoy's Avatar
    Central Calif.
    Is your HD set to "Cable Select"? Is your HD connected directly to the MB or a controller card?
    I have also heard that some Asus MB's acting exactly what you're experiencing.
    -DrumBoy.
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    Yep I had 2 - one was a refurb motherboard and one was new,
    both were asus - the refurb was the same as the new, but the
    refurb had a HP bios and did not work - the new one worked for years
    but started having trouble coming on - then it died, I swaped
    bios from the new one into the refurb - and it worked - till one
    day it did the same thing and died - a lot of times its the capacitors
    going bad on the motherboard - them small gateway Essential
    computers have that problem a lot
    have a look here
    badcaps.net
    Dec 2003
    Edmond, Oklahoma
    You guys are right, it is a Abit mobo. What do y'all think about this mobo as a replacement:
    http://www.newegg.com/Product/Produc...82E16813153014
    Dec 2003
    Edmond, Oklahoma
    Quote Originally Posted by DrumBoy
    -DrumBoy.
    I didn't connect anything to the IDE channels so that isn't a factor.
  1. Wierd Civic Problem
    By nester in forum Off Topic
    Last Post: 10-09-2007, 04:44 AM
  2. Troubleshooters! Computer turns off randomly and wont turn on, need help
    By phatbimmer in forum General MP3Car Discussion
    Last Post: 06-05-2005, 05:09 PM
  3. WIERD ps problem
    By Slitha in forum Power Supplies
    Last Post: 09-14-2004, 08:57 PM
  4. Wierd problem
    By alexchannell in forum General Hardware Discussion
    Last Post: 05-13-2002, 12:18 PM
  5. Need win98se full version help for a problem!!!!
    By jssaggie in forum Software & Software Development
    Last Post: 12-04-2001, 02:08 PM
