Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: how can you tell if a ceramic fuse is blown??(cardboard is covering glass)
    Constant Bitrate lominono's Avatar
    May 2005
    okay this is for my computer monitor and so i put it in "off topic"
    its a T4AH/250V and i think its blown. how can i tell if it is? it is covered by like a paper/cardboard thing.
    Maximum Bitrate techy101's Avatar
    Minneapolis, MN
    If you have a multimeter you can always set it to the continuity setting and see if it has continuity. If it does, it's not blown. If it doesn't it's blown
    May 2005
    naw i dont have one of those. i guess its time for radio shack.
    if the led light on the power button is all that is funtioning on the monitor is that becuase of the fuse(possibly blown) or is it something else?
    Registered User
    May 2003
    Use any audio input...your pc or your pc amps will do.
    Turn the volume high enough such that you hear a hum whenever you touch the input...NOT THE GROUND.
    Now place the fuse so that one end touch the audio input, then touch the other end with your finger to hear the hum.
    If you hear the hum then you know you got continuity, i know it work cause I just tried it
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by Chris31
    Wow, now that is clever!
    Installed.
    -GPSSecure- - GPS Tracking
    May 2005
    okay so if i read this right,
    audio input(mic? just where ever you plug the mic in),
    turn the system volume up, or the speakers?(probaly the system but not sure)
    do you feel the hum or would you put your ear to i guess your hand that is touching the fuse?
    Registered User
    May 2003
    Quote Originally Posted by xBrady
    Infact I only thought of it when I saw this thread while testing my PC speaker inputs with my finger
    Thanks to lominono for asking the qs at the right time
    Registered User
    May 2003
    Quote Originally Posted by lominono
    Lol...someone help this guy out, Im too busy to explain/draw right now.
    USA
    The $15 multimeter might be best in this case
    Installed.
    Variable Bitrate RS3RS's Avatar
    Aug 2004
    Springfield, MO
    My advice is to just buy a multimeter... Wal-mart has them for 10 bucks (automotive electronics section, where they sell the headlight bulbs and fuses and stuff). Any type of geek has to have a multimeter, comes in very handy.
  1. Fuse popping, wire heating up!
    By gumbi4u in forum Power Supplies
    Last Post: 06-29-2006, 10:01 AM
  2. Wiring, fuse, amp, relay questions
    By Vee24 in forum General Hardware Discussion
    Last Post: 05-25-2005, 07:03 PM
  3. Wiring Distribution Fuse Box, cable length etc
    By Pabs in forum General Hardware Discussion
    Last Post: 09-06-2004, 04:59 PM
