Results 1 to 7 of 7
Thread: Build a PC
    Question Build a PC
    Hi Guys,
    I have recently taken a new job and it looks like I am going to have to build a few new desktop PC's. (This company isn't big enough yet to just order 10 from Dell!)
    I'm quite happy building/installing etc. Though my knowledge on what components to get isn't brilliant.
    Therefore - I wouldn't mind a few opinions on :
    Motherboards - which is the most reliable make, gigabyte, asus, intel etc. I also need it to fit into a small desktop case (am I looking at Matx only ???)
    Processors - Do I go for P4 or will the new Celeron D be just as good.
    RAM - DDR400 ??? what other specifications should I be looking out for.
    HDD - Any make to stay away from ???
    PSU - The case I am looking at comes with 200w PSU, remember these are office based PC's no real graphics intensive stuff etc. Is that enolugh power.
    Cheers for your help guys.
    Matt
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    for the HD i would go with seagate barracuda
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    Constant Bitrate anitanium's Avatar
    May 2005
    Vancouver, BC
    a price range helps
    CPU: amd athlon64 if possible (good price/performance ratio)
    Motherboard: Asus, Gigabyte, MSI are all good brands
    RAM: DDR400 is sufficient.
    HDD: Seagate Barracuda (try for SATA 7200.8)
    PSU: at least 350W with newer p4 or amd cpus. any generic one will work fine
    [||||||||||||||||||||] - final touches
    SUPER 7" VGA w/ TS
    Toshiba Satellite 3000
    P3 850
    256MB
    30GB
    Geforce2 Go
    DVD
    Orinoco 802.11b PCMCIA
    nlite WinXP 350MB installed
    RoadRunner
    iGuidance 2.1
    Holux GM210 GPS
    Xantrex Xpower 300
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    TBH you may find it cheaper to actually buy the low end Dells, than to try to put PC's together yourself. You may in the short term save a few pennies, but long term it will probably end up costing you more.
    for example you don't know if the components you buy will work happily with each other, you will have the hassle of getting all the correct drivers to work with each other. You will have many points of contact if there is any support issues.
    When you add more PC's in the future you won' be able to get the same components, which means you will have all sorts of odd configurations again this will make support a nightmare.
    be hey, this is just my opinion.
    I know this was about a server but I think it is relevant
    http://www.icertify.net/index.php?na...highlight=dell
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    ditto. Ya want a warranty and service, especially in a business. Although if you want to stay busy with this, then build your own. Start with mobo and processor. I like amd
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
    The Lavender Tie Just
    Made It Obvious
    Rafster's Avatar
    Aug 2003
    San Diego, CA
    I would personally go with an MSI board. They are Imho he sturdiest boards out there. Go for something like an NForce 2 board.
    http://www.targetpcinc.com/Details.a...mID=3003&Res=2
    I have the ILSR (Firewire, Lan, Sound, Raid) version of this board for 1.5 years, no problems yet.
    Peace,
    Rafster
    Jun 2005
    MSI or Asus for Motherboards
    I would go P4 (not riced out P4's) for processors or a good AMD (no Duron)before I would EVER touch a Celeron!
    Probably PC 2100 or faster for RAM. You can find DDR 400 cheap though so I would go with PC3200 DDR 400.
    Hard Drives: stay the hell away from IBM! I would go with Seagate or Western Digitals.
    Power supplies should be at about a 300w minimum.
    There's my 2 cents.
  1. Car 5.1 Dsp Options Vs Pc 5.1 Dsp
    By port20 in forum Car Audio
    Last Post: 05-29-2006, 03:10 AM
  2. Build my PC?
    By diddy0071 in forum Newbie
    Last Post: 07-11-2005, 01:00 AM
  3. External PC Card adapter for Verizon BroadbandAccess
    By Bluebisz in forum Wireless Communications
    Last Post: 02-24-2005, 10:11 AM
  4. Power Question/Setup Question, minibook pc
    By seamonkey420 in forum Newbie
    Last Post: 05-17-2004, 10:47 PM
  5. need everything for a PC in car??
    By Hollis613 in forum Wireless Communications
    Last Post: 04-23-2004, 02:42 PM
