Have you tried removing the fog lights you installed to rule them out? Either you had a bad battery or you have a bad connection somewhere that is draining your battery. I would rule out the alternator since it tested fine at the alter. shop.
I suggest disconnecting any wiring you have installed. Then add one by one each item until the problem reoccurrs.
LinkBack URL
About LinkBacks
