i have tried to do that about a dozen times.
i even went as far as to delete all the software and replace it
thanx if you have any more ideas please let me know
ps i have the black razr v3 from cingular
try turning off your phone with it connected to the computer and turning it off and back on, I had do that a few times but it finally connected are you using the pk2 tool?
make sure you connecting with the right comm settings. find out which comm port your phone becomes when you connect it to the pc. then alter the setting in p2ktools to that comm and try it.
I have the same razr and I connect just fine its gotta be something on your setup.
MII12000 | 512MB PC3200 | 60GB 2.5" Samsung
M2-ATX 160W PS | SlotLoad DVD/CDRW | BU353 GPS
7" Lilliput 619 | WinTV | WIFI | Bluetooth
Audigy2 ZS | HQCT | Kyocera KR1 Mobile Router(3G)
Roadrunner | LSXvoid | IGuidance 3
My Worklog
Where will i find out what info i need
i can connect to the phone in mobile phone tools
but not with this p2k tools
thanx for the help
i downloaded the p2k tools from the link and also from Couple of forums
I am tryinyg to adjust the volume of my Razr phone and the error message says "phone not connected" when I select connect using the P2k software I downloaded from www.motomodders.net . When I plug in my phone to the USB port on my IBM (with internet firewall off) my computer recognizes the Razr phone and asks to look for software - I cancel out of that and try "connect" on the P2k program with no effect. I have disconnected and reconnected my phone as well as restarted the software - help please!!!
I have tried all of the suggestions to connect to P2K Tools.
I can connect in the AT mode, but not in P2K mode to update the Gain table.
Any other suggestions?
Sound like you are missing some drivers. If it just show up as a modem, then you do not have the correct drivers installed.
ODYSSEY
All information expressed in this post is my opinion, and should not be regarded as a statement of fact.Digital-Car UK|
(\__/)
(")_(")
You need to install Motorola's P2K drivers. If it just shows up as "Motorola USB modem", there are missing drivers. I am not sure about the legality of the drivers, so I can only suggest searching Google. Also if you can find a copy of PST, program made by Motorola to program phones, it comes with everything needed, but you are definitely on your own finding a copy of that.
You might have better luck searching sites like howardsforums or other cell phone related sites.
ODYSSEY
(\__/)
(")_(")
