one problem I went to the link you had posted for the P2k download and it isn't there any more.... What do I do?... I really need the volume louder too... please please help me..
Misty
I dont know about any of you guys who own a Motorola Razr V3 but the volume totally sucks on it! I can barely ever here anyone when im talking to them!. But not anymore! I have found a way to make the volume lots louder! Here is what you do:
Download P2kTools: here
Connect your V3 via USB to the computer. You can use the same usb cable that comes with most digital cameras instead of buying the motorola one.
Next:
Click on the green button "Switch To" And click P2K.
Then click connect.
After connecting to your phone go to "Tools" Click on gain.
Click "Get" and the settings should be at 0. You can change them to whatever you want. Max is 8. But i wouldnt go higher than 4. When you are all finished click set. Then Click on restart in p2ktools.
The phone should restart and you should be good to go!.
*This mod should work with most motorola phones. Just remember you can only do this via a usb cable and not bluetooth!
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
Misty
Here's the link for P2K tools for RAZR V3 and other MOTOROLA phones:
http://www.motoaide.com:8081/download.htm
Thank you so much... I am truly phone stupid at this point so... what do I need to do next? I downloaded pretty much everything from that site)
Originally Posted by MISTY76065
Come on bro, read the first post, install the software, make sure you download the drivers from that site, plug your phone into the USB and follow the rest of the directions on the first post....
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Misty sounds like a girl name to meOriginally Posted by Cheekz185
Installed.
-GPSSecure- - GPS Tracking
Yes I am a girl..I did download the stuff, however those instruction are NOT correct... but I did however figure it out.. thanks for the link to the downloads... You can't go to tools and click on Gain its not there... but you can go to the tabs below the the menu bar and click on OTHER FEATURES and on the left hand side there is the Gain Table adjustment it is simple slide bars and it works perfectly...
Misty
I'm glad it worked out for You...
anyone else get an error while trying to connect?
Car Pc progress meter:
[-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
"The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
My worklog
yes I did, and finally managed to connect by unplugging the phone from the usb cable closing the program and reopening it and then plugging my phone back into the usb cable..... you can try it worked for me...
Misty
