Results 1 to 10 of 11
Thread: HELP! - Jeep Cherokee Alarm Fault
    Newbie Jay2001's Avatar
    Jul 2005
    Leeds UK
    Hi all,
    Car: 1998 Jeep Grand Cherokee Orvis (UK)
    I have gone out to my car this after noon and the key fob has no effect on the car. When I press the unlock button my Jeep remains unaffected. The car next to mine bleeps and flashes it's indicators suggesting some interference but it doesn't unlock it.
    I have been out and purchased a new pair of batteries for the key fob, same result.
    I have tried the new batteries in the second key fob, same result.
    The car worked fine this morning at about 11am and this problem was noticed at about 4pm so something has gone wrong in those 5 hours.
    There is nothing in the car that could have drained the battery.
    If I unlock the door with the key the central locking doesn't work but I don't know if this is usual behavior as I have never used the key in the door before! It also doesn't unset the alarm or the imobiliser so when I open the now unlocked door the alarm goes off. Having closed the door the alarm resets after about 10-15 seconds.
    Anyone any idea what could be causing this, and more importantly, how to fix it before work tomorrow?
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Low Bitrate marshallh's Avatar
    Apr 2005
    Kansas
    Maybe your solenoids are shot, or the fuse for that was blown? My sister had the exact same problem with her Civic.
    Progress:
    [■■■■■■■■] 100%
    Mitsubishi 3000GT car computer
    Previous budget Honda carputer
    Jul 2005
    Leeds UK
    Quote Originally Posted by marshallh
    I am currently suspecting the sensor as I wouldn't have thought a single solenoid or fuse would take out alarm/imobiliser/central locking all at the same time...
    Jul 2005
    Leeds UK
    OK, well apparently the Alarm just needed resetting. Do any Jeep owners here know if there is a way to deactivate the security system without the keyfob?
    I am wondering what you would do if you were out in the middle of nowhere and the batteries went flat...
    On my rover you could enter a code using the key in the drivers door lock for example.
    Any one know?
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    why not just disconnect the battery and then reconnect it?
    Jul 2005
    Leeds UK
    Quote Originally Posted by binary.h4x
    That doesn't reset the alarm.
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Use the key to lock/unlock the RF door. If it doesn't reset (alarm turns off), there's a problem with that door lock cylinder (or actually a switch on the back of it)
    If it doesn't reset, try the LF door. Either door should reset it.
    EDIT: you're UK....I switched the doors above
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Jul 2005
    Leeds UK
    Quote Originally Posted by muldrick
    Sorry, you misunderstand. The Alarm had gone into a "Fail Safe" mode and could not be "reset" without the aid of a compenent auto-electrician. Nothing wrong with the keys, the door lock cylinders, or the key fob transmitter.
    Once in this mode unlocking either door with the key will allow that door to be opened but will not unset the alarm, the imobiliser, or pop the central locking.
    Thanks for trying though.
    Jun 2004
    South-Central PA
    Got ya'.
    That's messed up...what caused it? Hate to see this happen on a trip to BFE.
    I used to work on these and I remember if the wrong key was used, the car would crank and start, but then stall. After a couple of tries the starter would "deactivate". I remember once the starter quit, the customer would be screwed and need dealer service. Is this what happened?
    Still seems like you had a component failure or glits, if it wouldn't start to begin with.
  1. 83 Jeep Cherokee
    By Hellcat in forum Show off your project
    Last Post: 07-22-2009, 12:52 PM
  2. jeep grand cherokee install
    By jackjohnson24 in forum Newbie
    Last Post: 01-12-2005, 02:53 PM
  3. anyone know how many DIN a 1998 jeep grand cherokee laredo is?
    By Nav_Attack in forum General MP3Car Discussion
    Last Post: 09-08-2004, 07:12 PM
  4. 2000 Jeep Grand Cherokee
    By jmhenry5150 in forum Show off your project
    Last Post: 10-15-2002, 10:16 AM
  5. Jeep Cherokee
    By mnbujold in forum Off Topic
    Last Post: 03-07-2002, 07:17 PM
