Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Rained on my frickin' motor!
  1. #11
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Gotcha. Thanks Wizard and Zac. That seems to make sense.
    Off to the junkyards!!!! (I hope no one runs into me on the way home...)
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
  2. #12
    Underachiever ACHIEVER's Avatar
    Jul 2004
    Up in dat ass Ranking: Mr. 25,000!!! :) Posts: 10000 +
    Pat, I had the same thing happen on a car a couple years ago. The motor gets seized up as already mentioned. Sometimes/usually when this happens the motor is dying. But I was able to give it a little more "juice" by hooking a battery charger up straight to the window motor, bypassing everthing including the switch. Also you can try tapping on it with a hammer or something while powering it. My window still works fine to this day. Give it a try to save some work and money.
  3. #13
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Quote Originally Posted by ACHIEVER
    Ha Ha! I use to do stuff like that with old Rock Tumbler motors (Boy Scouts). Soaking them in oil for a few months sometimes did the trick, too.
    I liked your last girl better...
  4. #14
    Jul 2004
    Had any time to work on your window PatO? Curious what you ended up doing.
  5. #15
    Maximum Bitrate Psychobiker's Avatar
    Apr 2005
    Ireland
    Sorry, it eventually turned out I hadn't earthed the auto-down relay and it refused to do anything. Also let it dry out, working no prob!
    Sorry for my impatience
    L
    1996 Volvo 850 T5 CD - Eventually I'll start....
  6. #16
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Searched on that car part website for a replacement - no dice. So it looks like I either have to go to a dealer (puke) or fix it myself. I'll pull it apart this weekend and soak it and bash it for a few days...
  7. #17
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Dammit!
    Pulled the door apart today. The motor was RIGHT THERE! Just my luck - one friggin bolt was covered by a mounting bracket. I felt around the bracket and it looks like it stretches all over the inside of the door! I think I have to unmount the entire window to get the motor out! <ARRGH>
    It's pretty thick metal, too. I'll see if I can't drill a small portion out so I can get at the bolt - but I'm wondering if loosing the motor will cause the window to loosen up..
    It would suck driving to work with a plastic bag over my window!
  8. #18
    Constant Bitrate techeros's Avatar
    Mississippi
    have some good oil (white lightning or Pedros used for biking chains) and some fine grit sandpaper to clean the rust off the motor and brushes. glad i'm not you
    03' Toyota Tundra T3 Special Edition - Polk Audio speakers - Sony 4ch amp - RF Sub amp
    Carputer Planning |---------*|
    Overall Implementation |---------*-|
    (Stereo complete)
    Computer installed and working
  1. Headlight motor to raise screen
    By lostreception in forum General Hardware Discussion
    Last Post: 07-07-2005, 05:46 PM
  2. IGN controlled motor
    Last Post: 07-03-2005, 12:25 PM
  3. Smallest Motor
    By alienjj in forum Hardware Development
    Last Post: 05-09-2005, 07:41 PM
  4. reversable motor for monitor?
    By more mods in forum General Hardware Discussion
    Last Post: 12-12-2004, 05:20 AM
  5. Can I power a LaserDisc motor with the OPUS 150w?
    By afr0puff in forum Power Supplies
    Last Post: 02-27-2004, 09:28 PM
