Results 1 to 10 of 18
Thread: Rained on my frickin' motor!
    Maximum Bitrate Psychobiker's Avatar
    Apr 2005
    Ireland
    Hi,
    My electric window motor has been recently subject to a little h2o...window seal gone. I am wondering, since the motor hasn't actually burnt out or short circuited,that when it dries out it will work? Will it?
    1996 Volvo 850 T5 CD - Eventually I'll start....
    Apr 2005
    Ireland
    I need to know ASAP please
    L
    Poet Laureate rustyboxx's Avatar
    Feb 2005
    The Côte d'Azur of England - Hot totty central
    I don't see any reason why it shouldn't provided that there was no current to it when it was wet. IMHO and occasional experience it should be okay if you make sure all the moisture is dried out thoroughly before you allow power to it.
    Only true postwhores remember everything they post
    REP CLUB IS DEAD
    LONG LIVE REP CLUB
    Super Moderator xBrady's Avatar
    USA
    It should be just fine. I've got a motor for something else wet and after I let it dry out for a day it worked.
    Installed.
    -GPSSecure- - GPS Tracking
    Registered User
    May 2003
    Make sure you check the motor bearing/gear/mechanism for trace of rust...whatever you can see that might cause problems later. Just reoil/grease it.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Quote Originally Posted by Psychobiker
    L
    crikey! 8 minutes and then posting again!
    Jsut dont be so impatient with the motor. Give it a good couple of days to dry out and it should be fine. Its just like when you spill something on a remote control - let it fry for a few days and it willbe fine.
    May 2005
    Woodstock, GA
    IVe had whole computers submerged before. Just let it dry, and it will be no prob.
    Is this where the witty comment goes?
    97 Black pearl Mazda Miata MX-5 Carpc V2? maybee..
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    THREADJACK! (But slightly on topic)
    Diagnose this: Window doesn't roll down. But lights on the drivers switches dim (like normal) when that window is toggled. What's wrong?
    The dimming would imply that the motor is getting juice & the circuit is intact. That is assuming that the motor is wired through the switch - if it isn't, why would the lights dim? So, what can go bad with auto windows? Is it most often the motor, or do parts commonly rust/freeze?
    What should I expect before I crack the door open?
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    Raw Wave wizardPC's Avatar
    Jun 2000
    Nashville
    PatO:
    most often the motor has siezed. After that, the scissors that move the window up and down.
    Debt as of 1/1/05: $34,354.48
    Debt as of July 4, 2007: $0.00 explanation
    Total spent on wedding so far: $3885.79
    Thanks to everyone for your support.
    I'M DEBT FREE!!
    Zac
    Zac is offline
    Feb 2004
    VA
    and the lights dimming would follow that same idea - the motor is soaking up much more current trying as hard as it can to move.
  1. Headlight motor to raise screen
    By lostreception in forum General Hardware Discussion
    Last Post: 07-07-2005, 05:46 PM
  2. IGN controlled motor
    Last Post: 07-03-2005, 12:25 PM
  3. Smallest Motor
    By alienjj in forum Hardware Development
    Last Post: 05-09-2005, 07:41 PM
  4. reversable motor for monitor?
    By more mods in forum General Hardware Discussion
    Last Post: 12-12-2004, 05:20 AM
  5. Can I power a LaserDisc motor with the OPUS 150w?
    By afr0puff in forum Power Supplies
    Last Post: 02-27-2004, 09:28 PM
