do you have anything you can plug into your cig lighter to verify they both dont work?
So there is a chance there is another fuse located somewhere behind there? Cuz i know the fuse in the fuse panel isnt broken.
2002 Mitsubishi Galant
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
Souund Blaster Audigy2 NX
OPUS ITX PC Case
03' Toyota Tundra T3 Special Edition - Polk Audio speakers - Sony 4ch amp - RF Sub amp
Carputer Planning |---------*|
Overall Implementation |---------*-|
(Stereo complete)
Computer installed and working
yup....I plugged my cellphone cig lighter charger....and it doesnt work
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
ok time to breakout the volt meter..
you POSITIVE you got the right fuse?
humor me replace the fuse or put the volt meter on the fuse in question (continuity tester)
could be that the inverter pushed one of the two wires off the socket.. not sure how that could have happened
I am out of ideas believe it or not
(Stereo complete)
alrite i am going to have to work on it tomorrow!
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
pm me if you find something
(Stereo complete)
ok thanks bro!
Carputer Specs:
Via M10K
512mb Ram
60GB HDD
OPUS ITX PC Case
Originally Posted by Cheekz185
The traditional fusible link is a short section of wire that has a smaller diameter than the rest of the circuit. When current flow in the circuit exceeds that of the fusible link, the wire melts and interrupts the circuit. This type of fusible link is becoming quickly obsolete, as many carmakers have opted for newer technologies such as the cartridge style fuse element or maxi fuse. When a fuse link ?blows?, it must be replaced.
Purpose: Fusible links act as high-current fuses by protecting their circuits from excessive current draw. The capacity of fusible links is usually 30 amps or more-somewhat higher than that of standard fuses. When a fusible link blows, it means that its current-carrying capacity was exceeded and the heat across the link?s conductor caused the link to melt and open the circuit.
I don't think you would have a fusible link on a Cig lighter.
The last car I had with a true Fusible Link was a 1972 Ford F100 pickup.
If It's Called Tourist Season, Why Can't We Hunt Them?
I Just Do What the Voices Inside My Head Tell Me to Do.
The Definition of an Upgrade: Take old bugs out, put new ones in.
Texas DOS: Y'all reckon? (Yep/Nope)
Than check under the hood for the other fuse box(sometimes some car have another one in there).
kb5-
man thats a great def. of fusable links
I can't tell from your pic, but is that something similar of my pic below.
(Stereo complete)
