If you can be a bit more specific with the setup it may be easier to figure it out or offer another possible solution.
im trying to share my netzero connection between by two pcs using ethernet.
NetZero doesnt support ICS so im using Routing And Remote Access.
I set everything up just like the help file says to and the PING your supposted to do works but i still cant get on the internet.
P.S. This is my first post
Edit:
i have one computer with windows 2000 Server and one w/ Windows 2000 Pro. im using an ethernet connection between them. on the server i have a modem which i use to dial in to netzero. I want both computers to be able to be online at the same time but i cannot use ICS because Netzero isn't compatible w/ it. In the windows help files it tells how to share the connection using RRAS, so i did everything the way the file says but it doesnt work.(The PING TEST works but i still cannot connect)
Hey Enforcer, I checked out the link. Very nice, but talk about spending quality time with your PC. Too bad Netzero doesn't support ICS.
i got it partially working. when i type in an ip address it works but it doesnt work w/www's for some reason
because your dns server isnt setup correctly
also, not to be a prick, but what are you even doing here if this is yer first post, and its offtopic?do you have a carpc?
Roy
2005 Range Rover 4.4
You could use a program like RASSpy to help you use ICS.
ODYSSEY
All information expressed in this post is my opinion, and should not be regarded as a statement of fact.Digital-Car UK|
(\__/)
(")_(")
no, i dont have a carpc. i joined when i designed a carpc for a friend, but he decied not to get it. the thought occured to me that some one here might be able help me.
Quote by RoyN:
also, not to be a prick, but what are you even doing here if this is yer first post, and its offtopic? do you have a carpc?
What do you mean it doesn't support ICS ? Do you have a network connection ?
If so, you can make it work.
[H]4 Life
I'm a lesbian too.
I am for hire!
