Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 62
Thread: Acetone to Increase Gas Milage?
  1. #41
    Sep 2005
    Fort Myers, FL
    Okay, got more numbers for you guys. I'm calculating based on miles per tank because those are the only numbers that I have history for. I don't really have any MPG calculated for the van from before. So on tank 2 of 2 for the acetone mix, I got 382.7 miles, and then went back to straight gasoline mix, and got 381.3 miles. Keeping in mind that two tanks for me is about the same as six tanks for anybody with a decent car (i.e. 11 gallon tank instead of 32 gallon), I may yet try the 1 oz./10 gal. mixture ratio, but since I haven't seen any improvement whatsoever, I may just cancel the experiment entirely. I'm wondering if perhaps the make and/or model of the car has anything to do with the increase you get from the acetone mixture. Do imports get a bigger boost than domestics, perhaps? Will post new info as I get it. And I'll update the summary from my first post as well.
  2. #42
    Registered User
    May 2003
  3. #43
    FLAC alti's Avatar
    NY
    blah, I poop on this thread.
    no change in milage for me either.
    My Install
    Software:
    CFiG v1
    iGuidance Plugin for CF
    CarShell
    Working shell for a CarPC
    StopWatch
    StopWatch plugin remade for centrafuse RC1
  4. #44
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    Quote Originally Posted by alti
    But if you get a boost in performance, this could be an alterative octane booster...
  5. #45
    Registered User
    May 2003
    Quote Originally Posted by BoyNextDoor
    Just bear in mind the effect of acetone to rubber/plastic and such in exchange of something thats not even noticeable.
    Ill risk it if theres something really worth in returns though.
  6. #46
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    It's great for removing nail polish!
  7. #47
    Sep 2005
    Fort Myers, FL
    Still getting about the same, and I'm with the guys that say a small increase in performance is not worth having to replace all the o-rings and seals anywhere along the fuel line. I'll probably try the 1 oz./10 gal. mixture for 2 tanks, but if that doesn't show any noticeable improvement, the experiment is over as far as I am concerned.
  8. #48
    May 2005
    Derbyshire, UK
    Quote Originally Posted by Eric Lindsey
    Why exactly would you have to do that ?? It's extremely diluted (2 parts per 1000)...
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
  9. #49
    Registered User
    May 2003
    Quote Originally Posted by markbuts3
    Because it will "eventually" destroy something along the line. But honestly would you risk it for an extra 1mpg more? Having to bother to buy it from a shop, measure the amount and then put it in the tank for a sake of 1bhp? Ill rather invest in sticking an exhaust/air filter/sparks.
    If im getting 10mpg more and get like 10bhp, then yeah its worth risking. If something break then changing/threating all rubber/plastic is going to be a good move. I was only bothering with oil as fuel because Im buying the oils at 1/3rd of the diesel price.
    It is an interesting experiment but Ill certainly wont carry on with that kind of results persistently. However Ill carry on reading, maybe the engine needs adjustments? maybe the mixture is wrong? I just found another forum about it, Ill read up and post their conclusion
  10. #50
    Variable Bitrate HHdesign's Avatar
    Mar 2005
    Plano, TX
    This is proably the wrong spot, but since I dropped a FIPK in my jeep I've getting 2.5 MPG better, total suprize there. While not much, its a nice suprize. I think their OEM-drop in filter would give the same results.
    Jeep Grand Cherokee Laredo
    Kenwood X790 x/ iP500 Ipod Interface
    Elemental Designs 13Kv.2 D2
    CDT ES-620 (omg yayay!!!1)
    NINe.2X, NINe.2
  1. Whats your gas milage?
    By BoyNextDoor in forum Off Topic
    Last Post: 04-20-2006, 06:26 PM
  2. Gas mileage revisited...
    By wizardPC in forum Off Topic
    Last Post: 09-01-2005, 04:52 PM
  3. Car gas gauge problems, experts help!
    By CavityCr33p in forum Off Topic
    Last Post: 04-28-2005, 03:21 PM
  4. Fuel tank burst of gas...problem???
    By PoBoy in forum Off Topic
    Last Post: 07-02-2002, 10:19 AM
