Results 1 to 10 of 20
Thread: Help, scary lights...Accord Owners/ Mechanics please help
    My man uses Levitra. Peoples's Avatar
    Dec 2004
    Maryland
    Two days ago I installed the carnetix 5v POL in my car in the center console. This is right where the parking break cable runs through. (additional info....it is being powered by a fused distrobution block with the PC in the back..... its a 10 guage wire running up from the trunk...the computer is operating normally, and the POL is operating normally as well.)
    I'm not sure if this is related, but today I had 3 lights come on in my dash.
    Interestingly....these were not "check engine" or "service engine".
    They were, the battery light, the parking break light, and the "break lamp" light.
    I checked to make sure my break lights were working, and they were, no problem.
    Is there some kinda sensor right there in the center console that I could have shorted?
    please help
    PC Components:
    My work log
    Constant Bitrate ATXaccord05's Avatar
    Feb 2005
    Austin, Texas
    did you tap a wire in there? I think you said you got it elsewhere, but maybe i'm wrong. also check your battery voltage, and if it's not that, it might just go away by itself.
    Dec 2004
    Maryland
    The power is comming straight from the battery which is how its been going since easter. i didnt intentionally play with any wires in there at all. I'm thinking if i reset the ecu it should go away.
    PC Components:
    My work log
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    yo just take it to the honda dealer they will diagnose it for u or just unplug ur battery for a few minz then plug it back in and see if it goes away
    Feb 2005
    Austin, Texas
    when I put TYC's into my car my brake lamp came on, then went off right afterwards.
    MySQL Error MatrixPC's Avatar
    Sep 2003
    Beach City, Socal
    If those 3 lights come on at once on my Supra, I know that the alternator is on it way to heaven.
    With the engine running, use a meter to check if the alternator put out at least 13.5+ volts.
    Now turn on all electrical equipment you have in the car to see the light get dimmer (also step on the brake). Now if the engine still running without hiscup (sp?), the alternator is probably okay. The point is to see if the alternator push out enough juice to power all those electrical component.
    Another quick way (but dirty) is to remove the POS (+) terminal of the battery to see if it is still running. You have to be carefull on this test. I use this all the time. If the engine shut off after you disconnect the terminal, I am sure the alternator is 3/4 way to heaven already.
    Y2K Accord Dell GX150
    EmoRebellion is a SCAMMER
    Dec 2004
    Maryland
    ****.....i have a class d "1600 watt" amp (which seems to be pushing less then 800 watts, my opus, and the voltage regulator......i've seen people push much worse, why would my altenator suddenly take a dive?
    PC Components:
    My work log
    Dec 2004
    Maryland
    Ok. I disabled my fuse bear the battery for the amp, computer and voltage regulator. The lights went off. However I do notice my alternator making funny noise. Is it definatly a gonner?
    PC Components:
    My work log
    Dec 2004
    good buy stock honda alternator :-( we will miss you :'(
    dont stress it mines gonna go out soon too
    Sep 2003
    Beach City, Socal
    With Honda stock alternator?
    You may have a problem there and it is already 5 or 6 years old (if it's not been changed.) Try the remove the POS terminal trick.
  1. 2003 2004 2005 Honda Accord CarPC
    By Adam2312 in forum Newbie
    Last Post: 02-09-2009, 10:25 PM
  2. VW Owners / Dimming lights
    By TheSpatulaOfLuv in forum Power Supplies
    Last Post: 09-16-2005, 08:48 AM
