Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 33
Thread: How do you like my Home Made Generator
  1. #11
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    and there is no reason not to use some thing like a push mower
    I have herd about 10 people on the internet do that
    have a look here
  2. #12
    Maximum Bitrate kirbycope's Avatar
    Apr 2005
    Metro Denver
    I can think of a good reason to not but the parts for this:
    http://generatordepot.us/
    If you are a redneck and/or have the parts 'laying' around (neighbors shed?) than ignore my statement.
    Post Whore's tip:
    User CP-> Edit Options-> Number of Posts to Show Per Page-> 100
    http://www.frappr.com/mp3car from this thread http://www.mp3car.com/vbulletin/general-mp3car-discussion/65044-frappr.html
  3. #13
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    That's awesome. I would think a 12VDC generator with a storage battery like that might be hard to find, if they make anything like that?
  4. #14
    Mar 2004
    Los Angles
    nice job
    I'm planning to do the same thing but DC only for powering my system at car shows
    I thought you might want to know that an alternator wont make any more power after 2500 rpm so if you keep the engine at 2500 rpm you will still get max power and save a lot of gas
    my setup is going to have an electric start 2 stroke pocket bike motor
    I am looking for a controller that will sense when the voltage drops below 10.5v and will send a + or - pulse to a remote start unit so the generator will start by itself when it is needed
    does anyone know where I can find such a device?
  5. #15
    Feb 2005
    Jefferson, AR U.S.A
    Quote Originally Posted by kirbycope
    Well I do work on cars alot also - and a good heavy duty Battery
    Charger could cost up to a $150 - I use a 100amp alternator -
    so I got a 100amp battery charger - and thats why I put the
    rheostat to vary the power - I can charge up a almost dead battery
    in like 10-15 min with this,
  6. #16
    Variable Bitrate roadhog's Avatar
    Jul 2005
    Hampshire UK
    What an awesome job.
    That will cope with any power outages.
  7. #17
    Feb 2005
    Jefferson, AR U.S.A
    Quote Originally Posted by port20
    nice job
    I think my motor runs at 3600rpm max - I changed the speed of
    the motor all the way down till it stalled and it still puts out the
    same power, guess I got the pulleys right, a 4 inch on the motor
    and 2.5 inch on the alternator - At 3600rpm its running the
    alternator at 5700rpm with a 1.6 Pulley Ratio - I may try a 3
    inch pulley on the motor - but you need a bigger pulley to keep the
    motor from stalling - and just make sure your alternator fan is
    running the same direction that it is on the car - its set up to
    suck air from the back of the alternator over the electronics
    inside it - and blow out the front - even with that it will still
    get real hot
    here is a Pulley Ratio Calculator
    I will look into that controller
  8. #18
    Admin
    Aug 2005
    I built one of these ghetto generators last year. Did you realize you also just built yourself a welding rig? If you bypass the field control regulator and connect the field coil direct to a deep cycle battery, you've got youself a nice, cheap, portable DC welding rig. Just get a "stinger" for stick welding, some 6010 rod, and yer good to go!
    Have fun!
    -p.
  9. #19
    Feb 2005
    Jefferson, AR U.S.A
    Quote Originally Posted by gnomad
    Have fun!
    -p.
    I have been thinking about that - I was looking into
    a Zena welder
    I was going to use it with a 14.5hp briggs motor from a old
    garden tractor, - Its a 150amp welder with a 100% duty cycle
    I may try a home made one , I got a few old time Chrysler alternators,
    I may up grade one to a 100amps and just add it to my setup -
    I want to leave my regular alternator in place, this would be a
    nice welder for smaller things - angle iron and stuff like that
  10. #20
    Raw Wave tj!2k4's Avatar
    Oct 2004
    that's pretty sweet..
    is the bathroom next on your list?
  1. Going overboard with home made aux in?
    By Cambria in forum Car Audio
    Last Post: 07-11-2005, 06:48 PM
  2. Go Home funcion on Browse button.
    By Meelobee in forum Road Runner
    Last Post: 05-27-2005, 11:26 PM
  3. dell/gateway/emachine Vs. home made
    By Tricked-Out-Toy in forum General Hardware Discussion
    Last Post: 04-19-2005, 03:34 PM
  4. need switches for my home MP3 player
    By asteroid in forum General Hardware Discussion
    Last Post: 12-15-2001, 02:45 PM
  5. Nearing the home stretch... Advice? *LONG*
    By Sound of Silence in forum Software & Software Development
    Last Post: 01-15-2001, 01:45 PM
