Results 21 to 30 of 33
Thread: How do you like my Home Made Generator
  1. #21
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    Quote Originally Posted by tj!2k4
    that's pretty sweet..
    is the bathroom next on your list?
    Nope - it would be a crime to spend any money
    on that nasty mess, it would be like putting $10,000
    rims on a "insert small ugly car here" - Like polishing a turd,
    You know its possible to polish a turd - you would have to
    freeze it or freeze dry it , then just use sand paper
  2. #22
    What can I say? I like serial. Curiosity's Avatar
    Mar 2004
    Florence Yall, BFKY
    I'd rather clear-coat it first so it didn't smell.
  3. #23
    Feb 2005
    Jefferson, AR U.S.A
    Here is the alternator wiring for my generator
    its a CS-130 Alternator from a 89 chevy S10
    with a PLFS plug - head here for a service
    manual
  4. #24
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Just read the service info on this alternator, now thats an alternator I want in my car!
    Bet I cant find a UK vehicle that uses one.
    Lez, more widely known as flez1966
  5. #25
    Feb 2005
    Jefferson, AR U.S.A
    Quote Originally Posted by port20
    nice job
    I'm planning to do the same thing but DC only for powering my system at car shows
    I thought you might want to know that an alternator wont make any more power after 2500 rpm so if you keep the engine at 2500 rpm you will still get max power and save a lot of gas
    my setup is going to have an electric start 2 stroke pocket bike motor
    I am looking for a controller that will sense when the voltage drops below 10.5v and will send a + or - pulse to a remote start unit so the generator will start by itself when it is needed
    does anyone know where I can find such a device?
    I found some thing that might work
    Battery Alarm & Control
  6. #26
    Feb 2005
    Jefferson, AR U.S.A
    I decided to use the Iceberg modded alternator as a welder
    and just got remanufactured alternator for the Generator
    the Iceberg kit had six 50amp diodes - My thinking is that
    I could get 150amps max with it - the norm is six 35amp
    diodes from the factory - 3 diodes for positive,
    3 diodes for negative
    Here are a few links on how to make a alternator into a welder
    Jon's Jeep On-Board Welder Page
    BUILD A $20 PORTABLE DC ARC WELDER
    How to make a Homemade Tig Welder
    Homebrew Gasoline Engine-Powered Welder
    I will make a test rig first just to see waht it can do
    using a old 5hp tiller motor and the alternator/welder
    Here is my Generator all done
  7. #27
    Mar 2004
    Los Angles
    Quote Originally Posted by will1384
    Thanks for the info it might work
  8. #28
    Admin
    Aug 2005
    I have been thinking about that - I was looking into
    a Zena welder
    I was going to use it with a 14.5hp briggs motor from a old
    garden tractor, - Its a 150amp welder with a 100% duty cycle
    Hey, if you've got the cash, go for it! My rig was built from a 6.5 HP lawnmower engine I picked up for free (all it needed was a fresh tank of gas, a carb cleaning, and a new spark plug) and a 130A Ford alternator I picked up at the local junk yard for $20. Ford alternators are preferred because many of them have external regulators so you don't even need to bother with opening them up until you blow the diodes. So far, even that hasn't been a problem with just the 6.5 HP engine. I'd like to find a riding mower with a 12-16 HP engine, but these are a little more difficult to pick up free in nearly-running condition.
    What really makes my rig somewhat special is that I'm using a microcontroller and a large MOSFET to regulate the field current. The primary purpose of this is to provide a proper charge control for a bank of deep cycle batteries, and the system will kill the engine when the batteries have completed charging. Eventually, I want to put a servo/stepper on the throttle to save gas, and add the ability to shut down after the bulk absorption phase and leave the final topping-off charge to be handled with a small solar array.
    -p.
  9. #29
    Mar 2004
    Los Angles
    Quote Originally Posted by gnomad
    What really makes my rig somewhat special is that I'm using a microcontroller and a large MOSFET to regulate the field current. The primary purpose of this is to provide a proper charge control for a bank of deep cycle batteries, and the system will kill the engine when the batteries have completed charging. -p.
    are you using a PIC microcontroller if you are would you mind sending me the .asm file for it
    I am trying to expand my PIC programing skills and looking at your code would help me to learn what works and what dosen't work
    port20@socal.rr.com
  10. #30
    Feb 2005
    Jefferson, AR U.S.A
    -p.
    I have a 14.5hp key start briggs - It was my ridding lawn tractor
    few years ago - one day I was mowing grass and the rear-end
    just fell apart, I felt the tractor drop down - and look to see both
    tires had fell off - it only had about 2 years of use - maybe 50 hours
    at most of use - had a lot of problems with the tractor - things falling
    off - I guess the stock boy had fun putting it together
    Right now - I am just going to test with my converted alternator -
    I want to see a alternator weld before I spend $400 on a welder
    that looks like a alternator - I need a welder - my old sears
    230v stick welder - its worn out - has a short duty
    cycle, ect, ect, - Have to turn it up all the way just to get it
    to do any thing, even using the smaller rods, I have got a old
    5hp gocart motor that smokes real bad - and am going to
    weld a bracket in the morning for both alternators, one for
    welding one to charge the battery
    here is a few ideas - I am thinking about,
    the center alternator has a duel pulley,
    and I will be using turn buckles to tighten
    the belt - Its 3am me tired me go bed now
  1. Going overboard with home made aux in?
    By Cambria in forum Car Audio
    Last Post: 07-11-2005, 06:48 PM
  2. Go Home funcion on Browse button.
    By Meelobee in forum Road Runner
    Last Post: 05-27-2005, 11:26 PM
  3. dell/gateway/emachine Vs. home made
    By Tricked-Out-Toy in forum General Hardware Discussion
    Last Post: 04-19-2005, 03:34 PM
  4. need switches for my home MP3 player
    By asteroid in forum General Hardware Discussion
    Last Post: 12-15-2001, 02:45 PM
  5. Nearing the home stretch... Advice? *LONG*
    By Sound of Silence in forum Software & Software Development
    Last Post: 01-15-2001, 01:45 PM
