Results 1 to 10 of 14
Thread: sparks when hooking up coax?(kinda long)
    May 2000
    Ft Gordon, GA
    Question sparks when hooking up coax?(kinda long)
    ok i just got a tv card for my home pc. i installed it and set up the drivers. then i powered down the machine and unplugged it. when i accidentally touched the end of the coax to the back of the case sparks flew! they flew again when i touched the connector on the card with the end of the coax. well i did a little trouble shooting and found that it only does this when the monitor is plugged inot the computer. any ideas on how to fix this (sorry for the long post!) thx,
    etrik
    "if everything is under control, you're not going fast enough!"
    Nov 2000
    Chapel Hill, NC, United States
    Post
    My comp does the same thing, I've even gotten a little shock once or twice. I just ignored it and I havent had any problems.
    Got started with computers on this board early in high school...now I run a web development company and am about to build my dream machine.
    Unregistered User ODYSSEY's Avatar
    Feb 2001
    Raleigh, NC USA CarPC Ver3: [▓▒▒
    Post
    Doesn't sound right/good. I have an ATI AIW Pro and have never had that problem. What type of card are you using?
    ODYSSEY
    ODYSSEY
    Quote Originally Posted by Tidder View Post
    Digital-Car UK|
    (\__/)
    (")_(")
    Feb 2000
    hoppers crossing, victoria, australia
    Post
    ive gotten a shock of a coax network cable
    thats all
    cheers
    pcman
    never heard of being shocked of a tv out tho
    must try it NOT
    donate to my team in the ****box rally all proceeds go to the cancer council http://www.everydayhero.com.au/dodgy_mechanics
    May 2000
    Ft Gordon, GA
    Post
    its an stb desktop tv. its made by 3dfx.
    dartman: we're not talking a little shock, we're talking like it leaves black char spots where they touch! did you just hook it up anyways?
    etrik
    Nov 2000
    Post
    No, i never got black char spots, i think it has only happened a half a dozen times, it doesnt always happen. But I have seen/felt sparks and I just plugged it in and dont have any problems.
    Apr 2001
    Portland OR
    Post
    Originally posted by etrik:
    <STRONG>ok i just got a tv card for my home pc. i installed it and set up the drivers. then i powered down the machine and unplugged it. when i accidentally touched the end of the coax to the back of the case sparks flew! they flew again when i touched the connector on the card with the end of the coax. well i did a little trouble shooting and found that it only does this when the monitor is plugged inot the computer. any ideas on how to fix this (sorry for the long post!) thx,
    etrik</STRONG>
    If it is the coax from the cable company it is because the cable company and the computer are not sharing the same ground potential. The sparks are not a problem is you just discharge the cable to the case and not some IC on the motherboard. It isn't a problem and shouldn't cause any problems having the sparks unless they are huge and knock you unconcience.
    MPEGBOX - Plexiglass Computer
    www.mpegbox.com
    May 2000
    Ft Gordon, GA
    Post
    how would i go about discharging the cable? if i hold it to the case, the sparks just keep coming. thanks for all the help
    Jul 2000
    Orlando, FL
    Post
    It might be caused by a cable splitter/amp somewhere up the line. We just had cable hooked up at our new place, and the installer used a splitter/amp and it's powered by a wall wart located inside the house. The power adapter is hooked into the coax line, through a 2 way splitter, and feeds out to the amp on the side of the house. The adapter is rated for 15VDC, 300mA, which just might be enough to char up your case a bit. Plenty to cause the sparks.
    Not necessarily a solution, but at least a possible cause.
    Aug 2000
    Abbotsford, BC, Canada
    Post
    Hmmm... Try sticking your tongue in there next time to absorb the discharge...
    ~m
    PII 266, 512 MB RAM, 10 Gig, 36x CD-ROM, 16x DVD, DeLorme GPS, 5.6" LCD Screen, Dschmidt power controller, Keypower ATX DC-DC Supply, PowerAmp Macro controller, Dauphin mini-Kbd.
    Sony Head Unit, Sony Unilink input selector, rear deck Kenwood 6x9's, stock door spkrs... All in my '96 Civic, of course :}
    BC ROCKS!!!
