Results 1 to 6 of 6
Thread: AHH, HELP!!! SPARK IN COMPUTER
    Sep 2001
    South Carolina
    Exclamation AHH, HELP!!! SPARK IN COMPUTER
    ok, this is a bummer, i spent all day building my box, it looks great...but as i heaped all the cords, card, and other stuff in the middle of my motherboard, and flip the pc on to test it....i smelled something of a burning nature, and the lan card and something else caused a spark. I turned the pc off, and have tried to salvage it, but when turned on, the processor seems to run, the fans run, but nothing shows on my monitor, it doesnt sound like it is starting up (it did 5 minutes before i fried it) any help???!?!?!??!?!?!
    Computer:
    FV24
    custom plexi case
    p3 650
    6.4 lcd
    everything working...except stupid lcd isnt working with shuttle board
    Jul 2001
    Seattle, Wa.
    Post
    Originally posted by Shaggamuki:
    <STRONG>ok, this is a bummer, i spent all day building my box, it looks great...but as i heaped all the cords, card, and other stuff in the middle of my motherboard, and flip the pc on to test it....i smelled something of a burning nature, and the lan card and something else caused a spark. I turned the pc off, and have tried to salvage it, but when turned on, the processor seems to run, the fans run, but nothing shows on my monitor, it doesnt sound like it is starting up (it did 5 minutes before i fried it) any help???!?!?!??!?!?!</STRONG>
    Well your Processor is probably fried after the spark along with the MOBO and all the Memory on the board i cant think of much you can salvage from it, but i do have some questions that might help pinpoint the anwser
    how do you know the Processor seems to runif you are getting no video on your system? just because the fans are running does not mean the chip is fine,.
    was the lan card completely pluged in?
    were threre any loose wires in the box?
    You gave me fortune, You gave me fame
    You me power in your God's name
    I'm every person you need to be
    I'm the Cult of Personality
    Variable Bitrate Ashlawn Kemling's Avatar
    Feb 2001
    Williamsport, PA
    Post
    Try starting the system stripped! Remove sound cards, LAN/NIC cards, etc...
    Also, if the mobo has built in video... and you still can't get video out afterwards, get a spare video card and put it in and see what happens. Also, try using different configerations of the memory. So if you have more than one stick, you could switch their places around.
    --Ashlawn Kemling
    Apr 2000
    Little Rock, Arkansas
    Post
    does the computer seem to boot up (other than display)? does your hard drive process like its trying to start normally? If not then it is a)cpu, b)ram or c)video card. Replace each of these one at a time and see if anything is salvageable. Good luck.
    The Grand aMP3 Project
    Car: 96 Pontiac Grand Am
    Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
    Mar 2001
    Cincinnati, Ohio
    Post
    haha, the first time a read this, i thought it said "Help, shark in computer"!
    Clarion 200watt head unit w/ Aux in.
    Kicker 800watt 4 channel amp
    In a 96 Grand Prix SE.
    Sep 2001
    South Carolina
    Lightbulb
    ah thanks, i tested the processor (celeron 600), it works, the 128 stick of ram works, but i do not believe the video card works, any suggestions on a new one?? I want to run it to a simple lcd. Also, do you guys recomend dos or windows??
    thanks
    Computer:
    FV24
    custom plexi case
    p3 650
    6.4 lcd
