Results 1 to 10 of 12
Thread: relay and switch ?????
    Dec 2005
    i have a GM car. In the fuse panel there is a starter feed fuse, If i take the fuse out the car does not crank. So what i did was trace the wire under the dash cut it in half and put a switch in line with that wire, so i could have a starter kill.
    i was told that i should use a relay with the switch because the switch can't handle the current/amps and may soon fail.
    My question is how would i wire the relay with the switch so the relay could take all the current/amps.
    Maximum Bitrate binary.h4x's Avatar
    Jun 2003
    Fairfax, VA
    what is the rating on the fuse you pulled? and what is the rating of the switch you put in?
    here is a whole list of starter interrupts that you could do:
    http://www.the12volt.com/relays/page2.asp
    Dec 2005
    the fuse is 5 amps the switch is a magnetic reed switch don't remember the amp rating.my alarm remote start has a built in starter kill. Say if i'm sitting in my car listening to cd/dvd etc., and some one try to jack me i can maybe take out the thing that as the magnet in it out and run. I get away and they can't start the car. HaaaaaHHHaaaHaha hahhhahh ahha
    Dec 2005
    help me please
    Jun 2003
    Fairfax, VA
    there ya go, hooking that to your starter will only stop a theif from starting the car (unless they have time to find your wiring)
    If you want total control over the car, I would suggest a switch on the fuel pump. That way if you get jacked with the car running, just flip the switch and run.
    I think in most cars the fuel pump is already equipped with a relay, which means you just gotta cut the wire and put in a switch.
    Maximum Bitrate mushin's Avatar
    Aug 2004
    SE Michigan
    Quote Originally Posted by Aaron Ham
    help me please
    Bah, alright
    I think the reason no one's really come forward is that your question is so trivial (and I don't mean you any offence, we're all neophites at some point, but if you look up basic relay operations on google or whatever, you should be able to figure it out.)
    So you want to switch the starter line using a reed switch? Quite likely it can't handle 5A, so the advice to use a relay is good. You need to get a relay that is rated at least 5A @ 12V (most automotive relays will do.) Now wire the reed switch to power the relay coil. Then wire the starter line through the relay - when the reed switch closes, the coil will get power and close the relay, which will engage the starter line.
    edit: looks like binary beat me with a much more useful diagram. I'm leaving now :P
    Jun 2003
    Fairfax, VA
    Quote Originally Posted by mushin
    Bah, alright
    what? No more debating over physics?
    Dec 2005
    is this correct
    FLAC PatO's Avatar
    Dec 2000
    Afton MN
    Do you want the relay NO or NC? I'd say NC (pin 85a) - so that when the relay has no power, the car runs (like normal). When you close the switch, the relay is charged and breaks the starter(or fuel) circuit. Relays aren't meant to be charged 24x7 for years on end (I've had Bosch relays overheat during meets and boy is it embarassing!)
    If the theif gets smart, he'll disconnect the battery - thus enabling the starter(or fuel pump)! But then the starter won't turn... <doh!>
    My point is - if you're going to use this thing during a jacking, cool - go for it. But if you want to use this on a daily basis, get some sort of a "latching" relay. Search on that word for more info.
    http://www.jeepmp3.com/
    CarPC Stolen. Starting over.
    Ne1 recognize the avatar?
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    Quote Originally Posted by PatO
    Some are on all the time the car is running, IE fuel pump relay, power window relay...
    possibly some are made for longer duty times, like some are made for higher ampage.
    Lez, more widely known as flez1966
  1. xbox + inverter + remote start + relay switch
    By ozstriker78 in forum Power Supplies
    Last Post: 08-24-2008, 10:44 PM
  2. Bridge batt power for relay switch?
    By Ascension in forum Power Supplies
    Last Post: 06-20-2005, 05:38 PM
  3. Using a relay to switch on Lilliput
    By Vodkapete in forum LCD/Display
    Last Post: 11-18-2004, 11:57 AM
  4. Replies: 13
    Last Post: 09-20-2004, 07:01 PM
  5. Regulated/ unregulated relay switch?
    By mp3oplecarrier in forum Power Supplies
    Last Post: 06-01-2004, 10:05 PM
