Results 1 to 9 of 9
Thread: Surface Mount Resistor Help NEEDED!!!
    Aug 2005
    Near Buffalo, NY
    Ok I bought a led scanner to replace my third brake light. It uses 16 blue 5mm leds. Im replacing the blue leds to 16 red 10mm ones. The problem is that the led board regulates the voltage to 5 volts. Then uses 271ohm surface mount resistors of some size to drop it down to around 1-1.2 volts. I talk to the company that made the board and they told me I could replace the Surface mount resistors with lower value ones for more brightness. I did the calculations and found I need 100ohm 1/8 watt resistors to achieve around 3.2-3.4 volts at 20ma. The question is where do I buy surface mount resitors and what size do i need. here are some pics. The resistors say 271 on them and I tested them with a multi meter and found them to be 270 ohm resistors which is what I expected. Any input would be appriciated.
    Aug 2005
    Near Buffalo, NY
    Wrong section. Cant figure out how to delete this thread.
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    you cant. but good luck soldering smt resistors.
    Mar 2004
    Bristol
    you can edit the 1st post and remove all details and give a link to a new thread that you create.
    Aug 2005
    Near Buffalo, NY
    You dont think its possible. Ive soldered surface mount leds before so the resistors should not be a problem. Just dont know the size of the resistors on the board. Not the rating and all i know that but the physical size. So I can get the same size but a different ohm rating. Thanks JCarere
    Mar 2004
    Bristol
    i just hate soldering small things - got the shaked fromm too much booze and drugs!
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    http://www.digikey.com/scripts/DkSea...?KeywordSearch
    the link won't go to the page I intended, but here is the Digikey PN you need:
    rhm100fct-nd
    price is .47 per 10, or a whole 1.33 for 50 of them.
    Aug 2005
    Near Buffalo, NY
    Thanks I just found those about 15 mins ago and ordered some. Thanks for the reply. Is it normal for digikey to not know the cost of shipping? Anyway thanks everyone.
    Apr 2003
    Detroit, MI
    Quote Originally Posted by Jcarere
    yes, but they only charge actual sh.
  1. What materials needed to flush mount Xenarc?
    By Will Albers in forum Fabrication
    Last Post: 01-28-2005, 05:03 PM
  2. HELP! Xenarc Mount Needed
    By LarryMZ3 in forum LCD/Display
    Last Post: 07-29-2004, 12:17 PM
  3. Help! Xenarc Mount Needed!
    By LarryMZ3 in forum Classified Archive
    Last Post: 07-29-2004, 11:06 AM
  4. HELP! Xenarc Mount Needed
    Last Post: 07-23-2004, 09:15 PM
  5. Flush Mount Screen Needed!
    By bjm2020 in forum LCD/Display
    Last Post: 02-19-2004, 12:08 PM
