Despite the size issues, I have to agree that cards and non intergrated motherboards are the way to go, after my bookpc fiasco.
I'm getting pretty ****ed.
I've had no HD or CPU problems. But first I had a BookPC which arrived with busted ethernet. I exchanged it. Got it back and it worked great for a while, then the tv-out died without explanation or warning but it worked fine otherwise.
So I got an MS-6215. Works great for a month. Now windows gives serious msgrvfr rundll32 etc errors, and suggests I reinstall.
Reformatting and reinstalling gives the same errors so it can't even do post-install setup.
Disabling all onboard components that I can, same result.
Really friggin tired of this.
If I were just doing mp3s, at this point I'd just buy a damn empeg or something rather than dealing with flaky solid state circuitry. But I like CoPilot 2001 and haven't seen anything else, that's third party (i.e. doesn't come with car) that compares and I don't want to give it up.
Argh.
If I have to build a new system, I think it'll be with a fullsize mobo, and PCI cards for everything.
I'm SICK of this crap.
Player: Celeron II 633MHz, 256MB RAM, 20GB IBM 9mm 2.5" Laptop HD (180G/2ms), onboard ethernet/sound/video/tvout, 10"11"x3" case, MPBS1 70W DC-DC PS w/auto-shutdown controller, in-dash lighted switches, 7" NTSC TFT widescreen in-dash LCD, touchscreen, rear-window brake light installed Garmin GPS35 GPS, credit card sized IR remote w/IRMan, mini-wireless keyboard/mouse (sits under seat), PowerMate black knob, MP3s and GPS Navigation (Winamp, CoPilot, SA8.0).
Car: 1993 Nissan Maxima, Black Emerald
I cheat, I own an empeg.
Meskimen's Law: There's never time to do it right, but there's always time to do it over.
http://civic.mp3car.com
Alright, I found the problem. It was a DIMM starting to go bad.
The DIMM used to be fine, I had made sure to reseat it in case it came lose.
But it's behavior indicated some other problem, as it would always fail while probing for devices.
But I tried installing Win2k and got a data corruption error on loading the setup program for Win2k, and then at a different point next try. The change in the times it happened and that it happened when so little of the machine was being used (no device probing being done), made me try putting in a new DIMM..
and now it works
*sigh*
At least memory is cheap.![]()
Then why have I had to replace 2 HDs before I got my laptop HD? Of course, I am assuming I mounted in correctly...Originally posted by Charles Enwesi:
<STRONG>If mounted properly, NO HD should go back unless it is defective. Take it from me, if you do it correctly, it wont die.</STRONG>![]()
lol.... Like i said. Take a look at mine and u will see we both have two diff mounts for HD or what ever u want to call it. If you really understand mine and what i did, it will all make sense. Mind you that this is my 3rd box and I have never had my HD died on me. My mounting is based off my first prototype. It took 3 tries to and 2 DEAD HD to get it right. I will guarantee anyone out here if you do it like i did mine, it will NOT die on you. If it works in a Mustang, i see no reason why it shouldn't work on ANY car out there. On a side note, I too have a laptop HD that suddenly died not to mention that these things were built to take the beatenCan someone explain that to me and before someone says it was defective, nope.
abcd-1
