I think you'd better start saving up for a new motor..Well what do you guys think...
That white smoke indicates coolant sucked into the cylinder top end. You've got a cracked head quite probably. As a result of continuing to drive it, my guess is you've hydrauliced on coolant, and bent and or broke some **** in there - coolant doesn't compress, and something is going to give. Vibration above 2000 rpm is indications of serious primary imbalance of the bottom end now, which indicates you've probably done damage to the crankshaft as well. Your motor is done, but take it to a mechanic anyway for the post-mortum. Kinda hard to diagnose something from 7,000 km's away![]()
LinkBack URL
About LinkBacks
