Thanks blurp.
I'll make that change, and look at the other, also. I just have to do a tremendous amount of work tonight, without enough time, not to mention the tools, to do it. I'll look at it tomorrow or this weekend.
www.bradleyjacobs.com
There is more stupidity than hydrogen in the universe, and it has a longer shelf life. -- Frank Zappa
No problem.
Well, I think I have the issues fixed, except for the speed. I don't know of anything in my script that could be causing that. Here's the new one. Only unzip the vbs file, since you already have your ini file edited.
Just a recap on the instructions:
Unzip this onto your flash drive. Edit sync_files.ini and it will accept spaces in the names of your directories. Then all you have to do is run the script on each computer.
Just run the script on A, then on B
Then move files to A, then run script on A,
Then move files to B, then run script on B,
etc... until all you get is "Done" on both computers.
Note: To "reset" everything to sync new computers or new directories, just delete the ListA.txt and ListB.txt files from your flash drive.
blurp Thanks a lot man. This seems to work perfect now. It even runs faster. Really 2 hours before and like 40 min now.This is great. I will soon have all my files synced. Thanks again man.
UntenOps
Glad to be of service. someday I might even get time to clean up that nasty code.![]()
