Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: Oil Change every 5000???
    Jun 2002
    Cazenovia New York
    I have a new 06 mazda3. The manual says to change the oil every 5000 miles in my climate / driving conditions. This is the first car I have ever had that said to change the oil every 5000. I did the first change very early (out of habbit), my question is should I let it go anotherr 5000 miles or stick to the old 3000 rule??
    This post college life is a real drag
    Bowel movement jjh221's Avatar
    Dec 2003
    not sure yet.
    Quote Originally Posted by mespork
    No matter what i try 3000 rule always. I like to change my oil.
    I GIVE FREE HUGS!
    Buy Sell or Trade
    If my pm box is full, please feel free to call me any time. 440-328-3382
    Thank you
    Forex
    Rate Mp3car @ FXroot.com
    Constant Bitrate OoNikFraleyoO's Avatar
    Mar 2005
    Alabama
    5000 is fine. The 3000 rule was made by oil companies who benefit by you changing your oil more often. When I was younger I worked at an oil change company and truth be told, most cars say 5000, some even more. The 3 month thing is the same way. Its not gonna go bad just sitting there.
    Raw Wave BoyNextDoor's Avatar
    Aug 2004
    Walden, NY
    i change the oil myself, on a 5000 mile basis. I use fully synthetic oil though, 0-40 Mobil 1, the best oil for my car. It's actually funny, that back in europe you had to change the oil every 10-15000 KM ~8-9K miles apart. So basicly they are pulling everyones leg, by having this 3K mile rule. I don't do it only b/c it'd get mad expensive. I do my own oil change, and this way it cost's me ~$40. $5.50 per quart. plus a Mobil 1 filter for like $13. So it's pricey, but way worth it.
    I recommend you to use synthetic oil. It's better for your engine. Keep it maintained nicely, and you casn go 3-4, magybe 500 000 miles easy
    Dec 2005
    El Paso
    Personally I change my oil every 2500 miles. It maybe true that you can go 5000 mile or more but my theory is why risk it. It’s insurance. I want to get what ever trash there may be floating around in my engine out of there, be it metal, water or all the byproducts from blow by of the piston rings. I also change the filter every time, same reasons. From what I have see in car manuals, the 5000 mile thing usually say something like under normal driving conditions, but under harsh driving condition change every 3000 miles. There definition of harsh driving conditions is most people’s normal driving conditions, like stop and go, driving up and down some hill, driving for short distances, and stuff like that. Hope that helped some.
    UntenOps
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    Quote Originally Posted by UntenOps
    in reality, there is no such thing as normal driving conditions. But, also consider the type and weight your owner's manual specifies, and don't use something different. If your new Mazda says 5k is ok then do it. Just don,t get cheap and use no name oil and filters. there is a difference.
    every 2500 is overkill, unless your car sits for days at a time between drives. otherwise, 3-5k is not going to harm your motor at all, unless you beat the **** out of your car on a regular basis, or if you have a turbo which is oil cooled. Then, 2500 is ideal, and use synthetic. Mobil 1 is good choice, and has come down a lot in price. That stuff used to be over 5.00 a qt.
    Banned rev2's Avatar
    Dec 2005
    I do every it 5000 miles. Or when my engien eats the oil and I need to put more in
    Phillie Escalade182's Avatar
    Mar 2005
    Maryland
    Quote Originally Posted by rev2
    and your car also gets 11 mpg.
    Dec 2005
    Quote Originally Posted by Escalade182
    Yup
    Fun > MPG any day of the week
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    I do keep track of miles - but also look at the oil,
    if the oil looks burnt or real dark or smells bad - I
    change it out, if the oil looks good, I leave it alone
    the same for transmission oil, underware
  1. How to: Change windows shell
    By IntellaWorks in forum WinNT Based
    Last Post: 02-11-2011, 02:14 PM
  2. What would you do if your girlfriend.....
    By EsKALad in forum Off Topic
    Last Post: 01-25-2006, 01:50 AM
  3. Change voice in FD
    By Erwin in forum FreeDrive
    Last Post: 01-21-2006, 04:23 PM
  4. Sproggy 2.5 PSU. Can i run Via epia 5000?
    By tomis_86 in forum Power Supplies
    Last Post: 11-19-2003, 12:18 PM
  5. ebay change of password
    By cruzc_99 in forum Off Topic
    Last Post: 01-22-2002, 04:43 PM
