Results 1 to 4 of 4
Thread: Whats that Windows command to...
    Constant Bitrate Rith's Avatar
    May 2004
    P'cola, FLA
    When your reinstalling windows, the last thing you do is set up your name, and go through a couple steps that register and help set up a couple things. Their is a command to bring that back for the next time the computer is started (companies use this on a new build). Its a 3 buttom command, something like Control Shift F3, but I cant seem to figure it out. Does anyone know this command?
    CarPC Status:
    [||..........] 12%: Planning
    Have:
    • IRman • PS2 Remote • USB 2.0 Powered Hub • Backup HD
    Coming Soon:
    • Aopen Pandora • Celeron M 1.4 CPU • 256/512 DDR2 So-DIMM RAM • Lilliput 7" Touchscreen VGA • Car Power Supply (M/Opus)
    Variable Bitrate DaveB's Avatar
    Mar 2004
    Rith,
    Maybe we can back into this from another direction. What exactly is it that you want to do? Sysprep can be used to automate some installation tasks. Are you asking the question because you responded to something incorrectly and want to start over or is there some other reason why you're asking about this?
    8" Lilli TS
    MB896F Mini-ITX MB
    2GHZ Dothan 533MHz FSB CPU
    1GB SDRAM DDR2 533
    Seagate 300GB SATA150 HD
    ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
    Pioneer Slot Load SLIM DVDRW
    Bluetooth V2 USB 2 Dongle
    3COM BKP Cam
    May 2004
    P'cola, FLA
    Thier is a special name for it, but i cant remember. Picture this:
    You just bought a new computer from dell and you turn it on for the first time. It will prompt you 'Welcome to your new computer, lets take a few minutes to set everything up'. And you follow a couple steps.
    Once you install windows and install and updates and drivers, thier is a windows keyboard command that allows you to make it look like a first boot again for your customer. I just can not remember the command.
    CarPC Status:
    Have:
    Coming Soon:
    Mar 2004
    That's called the windows "out of box experience" or OOBE wizard.
    The files are located on a pc here:
    C:\WINDOWS\system32\oobe
    I'm not familiar with keystrokes to set the OOBE to run. But now that you know what its called you can probably google and find the answer that you need.
    8" Lilli TS
    MB896F Mini-ITX MB
    1GB SDRAM DDR2 533
    3COM BKP Cam
  1. New Frontend for Windows and Linux
    By gbr in forum Other Cool Front Ends
    Last Post: 01-21-2009, 09:55 PM
  2. Installing Windows 2000 Pro on a 1GB Microdrive
    By JeremyM in forum WinNT Based
    Last Post: 05-07-2005, 10:56 PM
  3. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  4. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 02:30 PM
  5. Running windows with no monitor?
    By BLACKOUT in forum General Hardware Discussion
    Last Post: 03-14-2001, 11:56 AM
