Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: clutch job on a 2001 Eclipse Spyder GT ~$859.44?
  1. #11
    Variable Bitrate 0okami's Avatar
    Feb 2006
    USA
    Quote Originally Posted by shotgunefx
    Did you ask on club3g.com? You'll get a lot more specific experience.
    actually, im having issues logging in to club3g, else, I would have continued a thread i started there. It seems cant log in via firefox, or IE on two different machines. Odd.
    Well, the car is currently in the shop. *high hopes that all goes well*
    I asked about checking all surrounding components, they said they do that by standard.
    I also asked about resurfacing the flywheel, also something they do in the process of changing a clutch they said.
    FLuids will be changed (he said most leaks during the repair anyway so thats also done in the process)
    TOB also changed...
    sounds like they handle all that should be... So it does not seem i have anyhting to worry about....
    I can even see the shop from here......
    *sits back by the window with a 300mm lens stalking the shop* ^_^
    (not meineke, its the one on the middle/left... image reduced down to 10% of actual size)
    ~0okami.Digital
  2. #12
    Raw Wave shotgunefx's Avatar
    Apr 2005
    Boston, MA
    I've heard of other people having intermittent problems. Think it's a DNS issue.
    Try http://205.234.104.182 and see if you can get to the site directly.
  3. #13
    Feb 2006
    USA
    hmm... that ip is not loading for me.
    "There is no website configured at this address."
    I'll try again later.
    Well, im back from the shop! And with good news. The car does not seem to have that slip condition anymore. No noise when out in neutral either.
    And whats more, the take off is *GREATLY* improved! so much that i accidently spinned the tires when going into reverse. The clutch feels totally different. Feels and performs like a whole new car! im impressed with their service. Looks like i found a new mechanic
    *happy*
    Now to take it out for a longer test drive...
    Anyway, a side effect: It seems that the horn is not working when locked with the remote. Also when panic mode is set off, the horn does not activate either... lights flash... and thats about it. I checked the horn from the steering wheel and fuses, and everything seems normal... but no panic mode, or lock confirm horn. wierd.
    ~0okami.Digital
  4. #14
    Apr 2005
    Boston, MA
    Quote Originally Posted by 0okami
    *happy*
    That is weird (the IP).
    Horn "Answerback" is a programmable item. Check your owner's manual on how to program it. Defaults to off IIRC and they disconnected the battery so it's forgotten.
  5. #15
    Feb 2006
    USA
    ah! problem solved with the horn!
    Loose/corroded connector.
    sand paper and a new terminal clip fixed it.
    ~0okami.Digital
  6. #16
    Apr 2005
    Boston, MA
    Had that happen to me before, but it happened when I was just using it normally, would wobble. (I've never had the horn answerback turned on)
  1. 2000 Mitsu Eclipse GT Aux-In
    By sxt173 in forum Car Audio
    Last Post: 03-03-2005, 10:31 AM
