Can you forward the port? http://portforward.com/english/route...outerindex.htm
PM me with the file/program you need and I may be able to help.
I'm trying to get a certain file from a well known site that happens to make you download another file to download the big file (I'll let you guys use your imagination on what kind of program I'm using.....)
The problem is that this program requires an open port where I don't have access to the router...
I downloaded PortScan 2000, and so far I've found supposedly 5 open ports. When I use the Nat/Firewall test on this downloader, with the port numbers it fails the test, almost as if these ports are actually not open...
Anyone have any clues? BTW, there is a reason why I'm being so vague... If someone thinks I can give more details without getting in trouble here... I'll go into further details...
Thanks,
Rafster
Spent so far: $1,755
Check Out My Work Log for Specs/Pics
CarPC Progress[!!!!!!!!!!!!!!].....Installation[---------+].....Pastrami Progress[!!!!!!!!!!!!!!]Don't mess with Texas.
It's not nice to pick on retards!
.Originally Posted by Rafster
Originally Posted by edrex
Installed.
-GPSSecure- - GPS Tracking
Well said.Originally Posted by xBrady
hmmm... looks like this thread is being watched![]()
Ok, lets see. Bit Torrents are not illegal. So, should discussing them be taboo? Yes, they can be used for illegal file sharing. But guess what? The main purpose of this site is discussing carPC's which are illegal in some areas. Besides that, we are talking about our cars which can most likely go above the speed limit so should that be censored since our car can be used to break the law?
If we can't have a discussion about legal programs then shut the thread down.
I just noticed this! Why the change?
well that was meant for what he said above that post. but the one below that and above this one too!![]()
OK, cool, I'll get right on that about forwarding the ports...
I'm trying to get a copy of Mappoints 06NA....
The Torrent App is called Azerus and the site I'm using is Seedler.org
But, now that I'm home, the torrent says... I can only leech from one location at a time.
I turned the other torent download off... WTF???
Peace,
Rafster
azures kills my pc! really hogs the resources.
