I used this machine http://www.bissell.com/Products/prod...URPOSE+CLEANEROriginally Posted by Red GTi VR6
with this in the machine
http://www.bissell.com/Products/prod...ANING+MACHINES
yeup - seen that too
crazy
Jan Bennett
and it didn't do anything?
how was the water that it pulled back up? did it make it any better?
if you did that and you didn't get any better results, then yes, I can see the dye being the next option
Jan Bennett
IT got better, but not as much as i thought. The water that came back black, but as you can see those brown spot and its annoying me. I still think that there is something i can do to take it out tho.
how many times have you done it?
many times I've had to do it over and over, you might consider getting a spray bottle of Oxy stuff and use that on top of the normal bissell stuff too.
Jan Bennett
i'd be putting some tfr on it
then washing out with lots of water
2001 Passat 130TDi Sport - Via Epia 15000, 1gb, 100gb, 220w psu, 7" lilliput motorized touch (chopped and in dash as a fixed), bluetooth, bu-303 gps, 7 port usb hub, tiny keyboard, netgear 54mb wifi, optima yellow top, ryder rt1170x, freecom dvb
you can't wash it with lots of water, the metal on the bottom will rust.Originally Posted by Ste_nova
ANd red what do you think about this
http://www.bissell.com/Products/prod...ct%5Fid=OxyPRO
sure.
the steamer products might work better, since you don't have the heat on the bissell.
the heat does wonders
Jan Bennett
ok i am going to go find one with heat.lol right now too.
