Results 1 to 9 of 9
Thread: internet connection monitoring software?
    And then I was mod. Tidder's Avatar
    Sep 2003
    New Mexico, USA
    I'm looking for some software that can monitor an internet connection (DSL) and create a log of how many times connectivity was dropped. Anybody know of such a beast?
    Tidder
    Try RevFE
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Windows XP ? Doesn't the event log show such a thing???
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Sep 2003
    New Mexico, USA
    Beats me. What would it be logged as?
    Tidder
    Try RevFE
    Elsewhere
    If you're directly connected to the DSL, you can use the Windows event viewer.
    If you're connecting through a router, it likely has a logging capability, which you could enable, as well.
    How about the Wiki?
    Jun 2004
    NH
    I honestly couldn't tell you. I've seen the errors or warnings before. Why do you think you've got a client with bad DSL service?
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    Sep 2003
    New Mexico, USA
    Well just the opposite. They're connecting to some inventory server in CA from here in NM using telnet thru a VPN connection. What'll happen is the VPN will drop connection, then reconnect pretty quickly. But, when that happens, their telnet session disconnects, and when they try to reconnect, they have to call the company in CA because their session is still open on the server, so they can't connect until it gets reset.
    Now the company in CA thinks its a DSL issue, but I don't think so. They think my client's DSL is diconnecting every so often. But from what I can tell, it's rock solid. I just needed a program that would log it so I could prove to them it's not the connection.
    I think those Actiontec DSL modems do have some kind of log thingy, I'll have to check. In the meantime, if you guys come across anything, let me know.
    Thanks!
    Tidder
    Try RevFE
    Nov 1999
    Ishoej, Denmark
    Do it the simple way.
    start --> run --> cmd enter
    ping 127.0.0.1 -t > c:\Pinglog.txt
    it will run until you press ctrl break
    Search for the textfile for connection problems.
    Only problem is there is no time indication so you dont know what time it disconnected.
    There are programs out there. I just dont remeber them.
    Hopes this helps a bit
    Nov 2005
    New Zealand
    Have had this issue with an DSL router before client would randomly get disconnected whilst using VPN and RDP switched routers and problem went away
    Also took client a couple of months to tell me as it was randomly happening so did not immediately check router and spent time checkin elsewhere
    Soltek Qbic P4 3.4G - 1GB RAM - Lilliput 8"
    1974 Ford Mk1 Escort
    Sep 2003
    New Mexico, USA
    Interesting, I do have a different brand DSL modem/router I could try, thanks esky. I'll give that a shot.
    Tidder
    Try RevFE
  1. Imaginative Uses Of Internet Connection
    By wolfebaine in forum Wireless Communications
    Last Post: 07-16-2006, 04:32 AM
  2. Need wireless internet advice / help !
    By coffeejolts in forum Wireless Communications
    Last Post: 01-29-2006, 06:35 PM
  3. Automatic Internet Connection?
    By chronot150 in forum Wireless Communications
    Last Post: 12-04-2005, 12:31 PM
  4. Replies: 4
    Last Post: 11-06-2005, 12:50 AM
  5. dual wifi cards - for constant internet connection
    By neon_eddy in forum Software & Software Development
    Last Post: 09-18-2005, 01:08 AM
