I tell you this, I've done a huge amount of research and designing on this, and you won't end up with anything that sounds good, plus you'll spend more money on the output transistiors than you would on buying a commercial, mass produced amp. Look on mouser or grey electronics for a pair of 100 watt mosfets, then imagine the 10 pair you will need, and all the control circuitry. Also figure out that you probably couldn't even build a decent crossover section or good filtering. If however, you're like me and just wanted to do it to do it yourself, go to www.tripath.com, and start emailing their techs. You can get the chips cheap, they're more efficient than a class D, and you can build some serious power amps. Plus, they have the complete schematics and white papers online. You'll be able to build an exact duplicate of their test board, putting out 1000-2000 watts, all you need to do is make a good input section.
Just my thougts on the idea. I'm also too busy to get all the parts together and spend 100 hours drafting up circuit designs...
Dave
LinkBack URL
About LinkBacks
Am going to use 4ohm speakers, as they have the same output/input specs as the 8ohm, except have lower frequency response, and have been reduced, so are cheaper..
lol
