Results 1 to 3 of 3
Thread: 6v or 12v batteries
    Constant Bitrate michaelrj9's Avatar
    Feb 2005
    Huntsville, AL
    6v or 12v batteries
    Hi all
    I am looking to put some good deep cell batteries in my boat to run boatputer,a air conditioner with other shore power accessories water pump etc...while motor off for long periods of time.
    I was looking at the torjan batteries
    The one that interested me was a 6v battery with 885 minutes @25 amp draw.I never seen one with that much reserve.
    If I get 2 of these and make it 12v will the 885 minutes @25 amp draw still apply?
    Would there be a problem after I hook them up in series to get the 12 volts then hook it up in parallel to the starting battery (12v) on the boat (to charge the 2 6 volt batteries that is now a 12v battery? from the alternator.
    Michael
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    keep the 6v's in series, and use an isolator. this way you can charge both batteries (consider the two 6v's as one 12 volt) from the boat's alternator. By using the isolator you won't have to keep reconnecting battery cables to charge them. Plus, you won't be stuck with a dead main battery if you drain the aux. setup. As for amp load and capacity, in series the amp and hour rating remain unchanged. If you were to connect the 2 6 volt batteries in parallel, you would have 6 volts, but double the amps.
    Feb 2005
    Huntsville, AL
    Thanks.
    Yea I forgot to mention that I was planning on getting the isolator.
    Michael
  1. -12V and -5V rails explained:
    By andrewb in forum Power Supplies
    Last Post: 03-19-2006, 11:52 AM
  2. FS: OPUS 150w w/ 12v 7ah Gell Cell Batteries $150 shipped.
    By fromplanetbob in forum Classified Archive
    Last Post: 10-07-2005, 09:17 AM
  3. How-To: Modifying the PW200
    By evandude in forum Power Supplies
    Last Post: 08-18-2005, 07:45 AM
  4. M1-ATX and heavy 12V rail
    By miki in forum Power Supplies
    Last Post: 05-13-2005, 08:18 AM
  5. 12V to 6V
    By AlphaFox in forum Power Supplies
    Last Post: 09-16-2003, 05:23 PM
