Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: Unpleasantries........
    Calm
    Down
    Or
    Get
    A
    2
    Week
    Vacation
    -Love
    The
    Forum
    Policeman
    Wiredwrx's Avatar
    Jan 2003
    Quote Originally Posted by 2muchwires View Post
    Before everything else, thanks for the quick reply and I recognize my dumb question It was appears that I think that you have a crystal ball that tells eveything, sorry for that.
    I recognize that I had not born on this forums (I assume that You did by your noobs argument) and that I gave poor/nothing info about my issue, here's what I have to say and if you don't like it michael just don't answer and forget this thread please. I already searched but there's nothing similar to what's happening to me.
    My m2 psu never turn on (I'm testing on my car) when I put the system in my house with a regular power supply it start working. I followed every step in the manual and reviewed again before reply.
    I'm trying to start it using the startup shut down controller, I will take Your advice and will recheck all the wiring I'm not perfect. I'm sure everything is fine regarding wiring and grounding but will recheck. Then tomorrow I will post.
    Listen here noob, I told you to search for a reason. You don't like it, don't post for an answer. When you ask a question in a room full of people, you don't get to choose who answers the question.
    Now, since you seem incapable of listening and following instruction, in a direct response to your question, and by the way, YOU STILL HAVE NOT CONFIRMED HOW YOU WIRED THE UNIT, OR TESTED THE WIRING. Just saying you wired it accroding to the manual means nothing. Did you actually find an accessory wire. Did you test it. Are you sure you have constant power. Does it come straight from the battery? What is the MB, there is a known issue with the early M2's and the Epia boards.
    Who cares if you have installed another carputer. Is everything between the 2 the exact same. Obviously not, because unless the M2 is totally dead, which I find hard to believe, though possible, unless you did something to it inadvertantly, then they would both be working, and not just one. Have you run a power calculator for this system. Probably not, maybe you are overloading the PS and it won't start.
    Why the hell should I have to sit here and spell this **** out for you when you can find it with a search. Why are you being so lazy about it.
    Now, read these darn threads I found for you on a search. Let me know when you follow ALL the suggestions in these threads.
    M2 ATX Problem
    M2-ATX Catches Fire is 1st 3 minutes!!!
    Another dead M2-ATX...
    m2-atx failure? mobo doesn't post..
    m2-atx shutdown/startup feature
    Why does it shut off hard for no reason?
    M2 ATX Power on problem
    Finally fixed M2-ATX not switching on Mobo!!!
    M2 Problem, Some advice please from those with the 'turn on' issue....
    M2-ATX not working? Not sure what happened.
    M2-ATX Wiring/ Keeping your carputer powered.
    m2-atx: is mine defective?
    Let us know when you are done.
    Michael
    Newbie ~Rob's Avatar
    Apr 2006
    UK
    woah - steady now!
    Are you sure the PC's not drawing too much for the PSU and did you use the PDF on the M2 website?
    MySQL Error Scouse Monkey's Avatar
    Mar 2004
    Bristol
    Hey Wired, take a pill, leave the guy alone and ***** off away from this thread!
    Idiot!
    Quote Originally Posted by Wiredwrx View Post
    M2 ATX Problem
    Michael
    Mar 2004
    Bristol
    PS Post reported. if you cant be civil then don't post. Oh and look at what is written under your name!
    May 2006
    As said time and time before - if you cant post with positive advice then **** off and dont post at all!! well done scouse!!
    FLAC Spaghetti's Avatar
    Jul 2003
    Spagcave, in da UK Today's phrase: J'aime Alizee
    No foncione
    In da club....
    ALIZEE WANTS YOU.....
    (\__/)
    (")_(")
    Bunny's first poo
    __ U
    FLAC sama's Avatar
    Feb 2006
    London, UK
    having looked through your posts, you're not actually a very nice guy Micheal. you must have wasted more time in all your posts actually telling people off, than helping.
    treat people how you'd like to be treated.
    Maximum Bitrate 2Fast's Avatar
    Feb 2005
    Bristol UK
    I agree with everyone else here, i bet you're the sort of person that honks his horn and shouts at people in traffic, why don't you try to be polite for a change, you may find that you like it.
    Elsewhere
    Quote Originally Posted by 2FastMR2 View Post
    I honk my horn and yell and gesture (yes, I do that, too) to let other people know that I feel their driving is unsafe.
    It's kinda like jumping up & down and waving your arms to get the attentioon of the person that's about to jump off a building. You've let them know that you're aware of his actions and the rude gestures let them know that you're displeased.
    Although, I also agree that WiredWRX snapped and went off on this particular n00b unnecessarily.
    While I wholly agree with his assessment of the OP's power issue and his presentation of the problem to the mp3car.com community for assistance. "I plugged it in and it doesn't work" isn't anywhere near enough information for anyone to truly diagnose a problem.
    Explanations of where wires run to, jumper settings, details about the setup, photos/diagrams, etc. are all exteremely helpful in diagnosing a problem.
    Basicvally, we have to determine if the OP is incorrect in his statement that everythign is wired up per the manual or if there's some other wiring problem or if the M2ATX is faulty or any number of potential power problems that could be in play here.
    While WiredWRX was certainly over-harsh in his response, the OP was just as n00b-ish in his request for assistance. Two wrongs don't make a right without some intense brainwashing.
    How about the Wiki?
    FLAC sama's Avatar
    Feb 2006
    London, UK
    but I bet you don't get out of the car, give them a proper breifing, go to your car, get some law books and show them some citations of how wrong they are, all whilst it's being filmed for lots of people to see over time!
