Results 11 to 20 of 22
Thread: Car Problems - electric ?? computer ?? vats
  1. #11
    Variable Bitrate will1384's Avatar
    Feb 2005
    Jefferson, AR U.S.A
    every thing - still checks out fine - I got ****ed and removed
    the computer and tried to start - just to see what it would do,
    It started and ran for about 20-30 seconds
    - makes me wonder even more -
    I thought about the crank position sensor - but I dont think I would get
    fire
    if it was the ignition module I would not get fire
    if it was the fuel system I would not have fuel
    and the battery is good
    it has to be the computer
    I wonder if I got a bad computer - or they programed
    it wrong
  2. #12
    Banned Motorcity's Avatar
    Apr 2003
    Detroit, MI
    The 3.1 will run with a bad crank sensor. That engine has 2 crank sensors and 1 cam sensor. If a sensor was bad, your check engine light would be on. Is it??
    Try this: Key OFF, hold gas pedal to floor. Keep pedal floored, do not pump. Turn key ON, then crank for several seconds. If it sounds like it wants to fire, keep cranking. But, do not crank for more than 15 seconds at a time. Doing this puts the computer in what is called Clear Flood Mode.
    Basically, it will reset the engine controller to default parameters. If/when the car starts, keep the pedal floored until it stops sputtering and starts to rev up. once you are at 2-2500 rpm (if you have a tach) slowly let off the pedal and allow the car to resume to a normal idle.
    Now, if your check engine light is on, you need to pull the fault codes to see what ails the beast.
    If you don't have a scan tool, or one of thosae cheesy code readers, you can cycle the key ON-OFF three times, ending with ON. Watch the check engine light. It will flash the codes. Each code will be 2 digits, and code 55 is end of codes. The flashes will represent each digit. So, a code 12 would be "flash" pause "flash" "flash"
    If you post any fault codes, I will decipher for you.
    god luck
  3. #13
    Feb 2005
    Jefferson, AR U.S.A
    Quote Originally Posted by Motorcity View Post
    god luck
    the bad thing is I have a scan tool, an AutoXray EZ-Scan
    - that used to read the car just fine but after what ever
    happened it wont - all it will say is "Vehicle Not Responding"
    - but it will read other cars just fine
    the check engine light is not on - but "service engine soon"
    stays on
    But I will try some of that stuff - when I wake up
  4. #14
    Banned xdjxklusivex's Avatar
    Dec 2004
    Diamond Bar, CA (909,951)
    prolly the computer bro but then again 100 degrees + shudnt effect the computer its made to stand up to even more
  5. #15
    Feb 2005
    Jefferson, AR U.S.A
    god luck
    I was able to use the clear flood thing - to start the car, but it never
    stops running a little ruff, it will stay running tho, but the exhaust
    smells bad - and when I press down on the gas it bogs down
    and then picks up - and I can not re-start unless I do the clear
    flood thing again -
    I got the auto xray to scan - but not the 1994 car setting that used
    to work with my car - but I was able to scan it has a 1995 car
    guess the computer is new-er than my car - but still no codes
    Thanks - never knew the clear flood thing
    Quote Originally Posted by xdjxklusivex View Post
    - It was a joke - my real brain in my head
  6. #16
    Feb 2005
    Jefferson, AR U.S.A
    I got thinking about - how the car acts after the
    clear flood mode and its running
    So I checked the fuel rail with the motor off its 45 pounds, thats
    about right
    So then I try the clear flood mode to get it running, its about
    35 pounds when running - thats not right
    So I am going to replace the fuel pressure regulator -
    and filter - for the heck of it, my book tells me it
    should be 40 pounds or more when running
  7. #17
    Feb 2005
    Jefferson, AR U.S.A
    I replaced the fuel filter - it was dirty but not to bad,
    still no go, replaced the fuel pressure regulator
    seamed to help - motor runs more stable in clear
    flood mode but wont start on its own, I found that the pipe
    going from the air intake to the EGR was pluged up -
    took 2 hours to clean - could not get a strait shot
    into that pipe/off shoot of the air intake - that helped a
    little more - I keep checking with the scan tool - no codes
    and my temp sensor - now said -38*f - and I get a code
    temp sensor to low - so I check it - wires have been put
    on with tape and twisted - so I remove that crap
    and use crimp connectors, I try to start the normal way
    and it starts - but its ruff, so I check VAC lines - and
    replace the one from the fuel pressure regulator to the
    map sensor, still no go - and I still have -38*f and
    a code "temp sensor to low" going to replace that
    going to check the 2 crank sensors and cam sensor
    but I never get any bad codes for them
    well it starts on its own - I guess thats good
  8. #18
    Apr 2003
    Detroit, MI
    Quote Originally Posted by will1384 View Post
    Temp sensor too low may not mean a bad CTS. You may have a bad thermostat causing the code for the coolant temp sensor.
    The low fuel pressure may be a concern, but I doubt it it this point. 35 #s is enough to keep the car running smoothly at idle, and should run ok up to about 2500 rpm.
    Have you checked the vacuum line to your map sensor? Also, getting back to the begining of this thread, did you ever find out if you popped any fuses or relays?
    Another thing is check your plug wires. The wires on the coil pack side, one of them may not be seated.
    On the engine side, those long boots tear after a while, and you may have a spark leak. I had 1 bad wire on my wife's, and at idle the engine was smooth for the most part, but as I rev'd it up, it was bogging down and stumbling. I got lucky on which wire was bad. I could hear a "crack" sound when I rev'd up (outside by hand moving throttle) and I looked and could see the spark jump outside the boot and ground out at the head.
    Repalced wires, car ran smooth as silk.
  9. #19
    Feb 2005
    Jefferson, AR U.S.A
    yea I am shure the temp sensor is bad - going to get one today
    and the plug wires are good - but who knows how old, there getting
    replaced - the vac line to map sensor is good - and the scan tool
    reads it fine, I still dont know what kiled that light fuse or why
    that kiled my car , but yes I have checked all 4 fuse
    boxes, even removed fueses/relays and made shure the contacts
    were clean
    right now I am just throwing parts at it - The good news is,
    that if I keep doing this, some day I will have a new car
  10. #20
    Feb 2005
    Jefferson, AR U.S.A
    the temp sensor helped a lot yesterday, but it stll idles
    rough, replaced the cam sensor that on top of the motor
    under the power steering pump , no change, replaced
    the spark plug wires, old ones were good, but real old,
    no change
    next will be the crank sensors
    right now it will start just fine, and idle good for a few seconds
    and then start getting a hair rough, if I rev it up, it does good
    but when I let off the gas, it all most seams like its going to die
    and then it recovers, and goes back to a idle thats a hair rough
  1. The legalities of wardriving.
    By PURDooM in forum Wireless Communications
    Last Post: 01-29-2008, 06:26 PM
  2. Installing car PC in 1996 Honda Civic
    By PredatorCoder in forum Newbie
    Last Post: 08-18-2005, 08:58 AM
  3. Will a car computer mix with subwoofers.
    By Jcarere in forum General MP3Car Discussion
    Last Post: 08-06-2005, 12:35 PM
  4. Power problems with car computer :(
    By Bitflip in forum General Hardware Discussion
    Last Post: 04-26-2004, 04:13 PM
  5. Ok, new car and new computer HELP
    By rhurley in forum General MP3Car Discussion
    Last Post: 10-07-2003, 03:01 PM
