Results 1 to 10 of 10
Thread: Anybody into SQL?
    Jul 2001
    The Netherlands
    Anybody into SQL?
    Hi all,
    long shot, but I'm looking to solve a problem I have, I need a sql-statement which is like this:
    insert into prijslijst (product,retail_prijs,nl_gelijk,[<_Exp_1],Exp_1,Exp_1_aantal,Exp_2,Exp_2_aantal,Exp_3,Exp3_ aantal,Oudh,Topcons,Afinor,Beaver, Argend,[M-east],Samengesteld_uit,Hoofdgroep,interne_code,NS,code) values ('', '', '', '', '', '', '', '','', '', '', '', '', '', '', '', '', '/1/', (select max(interne_code) from prijslijst), FALSE,'')
    but actually works!
    anybody... please...??? I'm going bunkers over this, there must be a way to do something like this, I just can't figure out how....
    trhanx!
    If at first you don't succeed.........
    destroy all evidence you tried
    for info on t6369c LCD or Presslab's powersupply check:
    http://www.namms.tk <=updated!!
    Maximum Bitrate Raas's Avatar
    Jan 2001
    The Netherlands
    what kind of db is it ??
    what do you want to do ??
    If the info is not to critical send me a copy of the table and a description of what you want to do, and then I will see if I can help..
    Greetz.
    Raas
    (mark.raassens@12move.nl)
    Raas - The Netherlands
    ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
    GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
    Aug 1999
    Upper Marlboro, MD 20772
    if this is mysql, then you have ur work cut out for you.
    abcd-1
    Mar 2001
    Cincinnati, OH USA
    What error message does it give you? I believe one of your variables (code) is restricted and can't be used, try changing it. If it is an Access database try running it within Access, it should help you out. Also is it for the web or just a database for your use? One resource I commonly use for web database problems is http://www.aspmessageboard.com (try searching with the error message).
    http://www.mp3car.com/usersites/Maveric/ M.A.V.I.C. System
    Asus MB, PII 266, 192 MB Ram, 6.8" LCD, 6 Disk CD-ROM, 21 Gig HD, All-in-Wonder Video w/ TV Tuner, Irman, Windows ME, Winamp, Cobra III -- All in a custom acrylic case.
    http://www.mp3car.com/usersites/listings/ MP3car Listings - Please add to it! :)
    Nov 1999
    Ishoej, Denmark
    This advide is based on microsoft sql server, and may not work on other types!
    Appart from (code) could be a reserved word, the < character may cause it troubles as well (even if its in [] )
    One other thing may cause you a problem. If the interne_code doesnt allow null and you are trying to insert the firstvalue it will most likely fail.
    If this is indeed your problem use a command like ( isnull). meaning it would look like this
    insert into prijslijst (product,retail_prijs,nl_gelijk,[< _Exp_1],Exp_1,Exp_1_aantal,Exp_2,Exp_2_aantal,Exp_
    3,Exp3_aantal,Oudh,Topcons,Afinor,Beaver, Argend,[M- east],Samengesteld_uit,Hoofdgroep,interne_code,NS,
    code) values ('', '', '', '', '', '', '', '','', '', '', '', '', '', '', '', '', '/1/', isnull((select max(interne_code) from prijslijst),''), FALSE,'')
    But as the others have stated we need more info to really help you out. especially the COMPLETE error you get, and if possible the table construction info (fieldnames, datatypes, properties(allowsnull, defaultvalue etc))
    Appart from that we would like to know what system you are trying to run it on ie: microsoft, oracle, sybase, mysql etc. We may need that info because every sql server type, has its own quirks and weird little details that can trip you up.
    Good luck
    Jul 2001
    The Netherlands
    the error I'm getting is -3058 undescribed error
    nah problem is the select statement in the insert statement, if I remove this by a "normal" integer value all goes well.
    It's just that I really didn't wanna use 2 queries. but hey if that is the only option......
    Apr 2001
    Here, There, Everywhere
    yeah some DB's dont support sub-queries within INSERT/UPDATE statements.... MS SQL is one of em.....
    also is that MAX() function returning an integer from the specfied DB table? IF you have no records in that table it will return NULL which will trip it up.....
    you can use the COALESCE function with MS SQL which will replace a occourance of NULL with a specfied character.....
    thus
    SELECT COALESCE(MAX(foobar),-1) FROM tablename
    will return -1 in an instanace where MAX() returns NULL....
    Project - GAME OVER :(
    Nov 1999
    Ishoej, Denmark
    magnetik is partially right It doesnt allow you to do sub queries like that but it does however allow you to do this little trick
    (This is frmo one of my databases convert for own needs)
    insert into aisle (name, description) (select max(aisleid),'test' from aisle)
    Notice that the "value" is gone and that only the select is left, thus allowing you to insert your complete select
    Hope this one fixes the problem, otherwise we do need to know the type of server (if you dont want to say your are using a full blown mssql server(is anyone listening ?). then say your are using the msde (microsoft database engine), which is for free (under certain circumstances, and will do almost all the things an ordinary ms sql server will do.
    Please let us know if you get your problem solved, since i believe that most of us are more than willing to help you out.
    Jul 2001
    The Netherlands
    Darkwingduck your the best!
    Ah never thought of using a "fake" multi-row insert!!!
    Thank you very much.... this really helps me I've been coming across this problem pretty often, now I have a way f solving it!!!
    Nov 1999
    Ishoej, Denmark
    Glad to help and glad to se that it worked
