Results 1 to 10 of 11
Thread: Dryer wont start! (it starts, but, as soon as the button is released, it stops!!)
    Low Bitrate wardemon666's Avatar
    Jun 2005
    I have a Moffat clothes dryer and it wasnt drying very well (it took two whole cycles to dry a batch of clothes) so I took it apart and found out that the back end of the drum was clogged, and the vent going outside was also pretty clogged.
    This is the second time I take it apart, first time was because a bushing of some sort was gone and it was squeaking. When i put it back together the first time it gave me the same problem, i wasnt able to keep the dryer running, when i started it, as soon as I let go of the start button, it would shut off. I fixed it by taking it apart, finding no problems, putting it back together! I didnt do anything and it fixed itself! This time, everything I try wont let it start by itself...
    What could be the problem?
    if i close the door it starts but doesnt stay on...
    if i open the door it doesnt even start
    so im guessing that switch is still good..... what do you think?
    here are some pictures that could aid in finding the problem:
    To view all the pics in a gallery:
    http://img213.imageshack.us/gal.php?g=dryer014lc8.jpg
    or seperately....
    http://img213.imageshack.us/my.php?i...ryer014lc8.jpg
    http://img213.imageshack.us/my.php?i...ryer013ld0.jpg
    http://img213.imageshack.us/my.php?i...ryer012ke5.jpg
    http://img213.imageshack.us/my.php?i...ryer010tb9.jpg
    http://img213.imageshack.us/my.php?i...ryer008ip0.jpg
    http://img213.imageshack.us/my.php?i...ryer003am3.jpg
    http://img213.imageshack.us/my.php?i...ryer001em6.jpg
    Thanks everyone!
    Mar 2006
    Colorado, but Canadian!
    hang up the clothes and use a blowtorch!!!
    1.9in x 2.9in -- 47mm x 73mm
    Jun 2005
    Quote Originally Posted by 2k1Toaster View Post
    nooooooo
    seriously,,,, ideas?
    Mar 2005
    NY
    that is usually a safety feature take it apart and put it back together again! Do it right this time!!
    Carputer Progress: Here we go again...
    THE GF THEME
    Genesis has speed
    Genesis has class
    Genesis sent money
    before your a__;)
    Join the fight against carputters. EMAIL ME!
    Jun 2005
    Quote Originally Posted by Genesisfactor View Post
    but there are no sensors for the dryer to actually know that.... i dont think thats the answer
    Constant Bitrate Pathos's Avatar
    Jun 2004
    St. Louis Mo.
    Check the connections on your Opus
    "A rose by any other name is still a flower"
    Jun 2005
    just forget about.
    Constant Bitrate pate60's Avatar
    Jun 2004
    Auckland, New Zealand.
    i'd love to see the install pics!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    What's this?
    It looks like some kind of a door sensor.
    Barring that, it sounds like some kind of relay is not closing. When you hit the start button, it probably closes some kind of a relay that handles the big power requirement of the motor and heater element. It sounds like that relay doesn't latch closed when you let go of the button.
    Want to:
    It's not really that small...No, seriously. judoGTI's Avatar
    Feb 2004
    Florida
    Well depending on the dryer it either has a temperature sensor or a moisture sensor. This tells the dryer when its time to turn off (or when it thinks the clothes are dry). Im guessing yours is faulty or you have a short and its causing it to turn off immediately.
    See if you can dig up a manual for it and see where it is and test it out... Or pay a repairman.
    '02 GTI
    [Routis '04] [Opus 90W] [160GB Maxtor HD]
    [Lilliput 7" TS] [VIA M10000] [XMPCR]
    [512MB RAM] [Custom housing]
    [Deluo GPS Mouse] [E-MU 0404 Soundcard]
    Progress Meter: [==============|] 99.9%
  1. LSX (VOID) released
    By liquid_smoke in forum RR Skins No Longer Supported
    Last Post: 03-01-2007, 10:43 PM
  2. Engine Start button?
    By Akuma in forum General MP3Car Discussion
    Last Post: 09-06-2006, 03:22 PM
  3. iGmod Beta 2 release
    By PURDooM in forum Other Cool Stuff
    Last Post: 05-12-2006, 02:52 PM
  4. extra button to start up carputer???
    By lockylocke in forum Newbie
    Last Post: 06-20-2005, 07:08 PM
  5. Replies: 2
    Last Post: 04-04-2005, 03:45 PM
