Results 1 to 10 of 16
Thread: little help with a computer build
    Oct 2004
    allright so im putting together a computer for my cousin. we get it all put together and cant get anything to show up on the monitor. now ive never put a computer together with a dedicated video card from the start. is there anything special i need to do to get the bios to display? it should just come up so i can boot to a cd correct? am i completely missing something here or what? heres the parts.
    A-DATA Vitesta 1GB (2 x 512MB) 240-Pin DDR2 SDRAM DDR2 667 (PC2 5300) Dual Channel Kit System Memory Model ELJPE1908K - Retail 107.99
    Intel Pentium D 805 Smithfield 2.66GHz LGA 775 Dual Core,EM64T Processor Model BX80551PE2666FN - Retail $94.49
    ECS NFORCE 570 SLIT-A (V5.1) Socket T (LGA 775) NVIDIA nForce 570 SLI ATX Intel Motherboard - Retail $99.99
    POWERCOLOR X300SE64HM256 Radeon X300SE HyperMemory 256MB HyperMemory (64MB On board) DDR PCI Express x16 Video Card - Retail 33.99
    Western Digital Caviar RE WD2500YD 250GB 7200 RPM Serial ATA150 Hard Drive - OEM $69.99
    Rosewill RFA120L-B 120mm 4 Blue LEDs Case Fan - Retail
    Fisher Customs
    www.fishercustoms.com
    AMD mobile Athlon 3200+, 512mb ram, M2-ATX, 8" dynamix 16:9, powermate, 80 gig hd, 802.11G PCI w/ stubby antenna, SB Live Soundcard, hardwired into stock Bose system
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Make sure the RAM is seated properly?
    Is it powering up? Have you connected the power switch correctly? Any beeps?
    Oct 2004
    it powers up and then after like 10 seconds there is a few beeps. the only thing i cant get it to show anything on the monitor. i tried taking both ram sticks out and it doesnt beep then but it sitll doesnt show anything on the screen. if the sticks of ram were bad or incompatible wouldnt it still show the bios?
    Fisher Customs
    Nov 2003
    Massachusetts
    Have you tried one stick at a time? It sounds like it is at least trying. In my limited experience of boards with no onboard video you should get a display. Is the video card seated ok? Does it require external power?
    Oct 2004
    on it doesnt require external power and yeah i made sure it was seated properly twice so i dont know. i tried one stick of ram also. might hafta run in and get another video card to use with a different lcd monitor and see if it works. theres another thread on here about a samsung monitor and having problems using the dvi input. maybe if i use analog it will work to get video for now.
    Fisher Customs
    Oct 2004
    NY
    you should get at least a low res display unless it defaults to an on board video, if there is none you should by default get the display, & then you need to install the drivers to get higher res usually..
    beeps are usually a trouble code... find out what the # of beeps means for your board is usually a good first clue too..
    Oct 2004
    i tried to find out what the beeps mean but its not a regular beeping so ill hafta listen to it a little better tonight. would the memory be causing this? thats all i could think of. unless the motherboard is dead? when i took the memory out it didnt beep but still got no picture.
    Fisher Customs
    Oct 2004
    NY
    could be memory, could be something else... try to check the beeps.... that might tell you...
    Oct 2004
    well i got the beeping to stop. i had a 2x2 power connector plugged into the motherboard which was causing the beeping. not sure why that stopped it but it did. now i still cant get any video at all on the monitor. i guess im gonna go buy a different video card and see if that fixes it.
    Fisher Customs
    Mar 2006
    Colorado, but Canadian!
    The 2x2 connector is the P4 connector. Required for most intel chips to boot up. It supplies a dedicated power stream from the PSU for the CPU for times it needs lots of power.
    And the Pentium D's are trouble makers. I have had this happen a bunch of times. Basically the board "supports" the pentium D, but not. You need a BIOS update. Every Pentium D I have put together required this. Same problem too. Looks like it is working, fan on, a beep, lights, everything, but no video.
    It is because there are no clock cycles, so it goes once and that's where all that happens. So what do you do I hear you cry!
    Really the only way to update the BIOS is to get something to tick, so you need another CPU. A temp CPU if you will. Basic P4 Celeron or something cheap. Plug it in, and it will work. THen update the BIOS, and stick the Pentium D back in.
    I do this so often I have a spare cpu now, but before I went to CompUSA and "Rented" (21 day no questions ask return policy for 100% refund) a basic $20 cpu that at the store costs like $120 and slapped it in, updated the BIOS, and plopped in my good Pentium D.
    I am almost 100% certain this is your problem.
    1.9in x 2.9in -- 47mm x 73mm
  1. Making a Car Computer; Need Your Help!
    By Fear Effect in forum Newbie
    Last Post: 08-18-2008, 10:51 AM
  2. What kind of computer to pick
    By pulz in forum Newbie
    Last Post: 02-02-2006, 05:08 PM
  3. Computer Crashed?
    By Rocky388 in forum General Hardware Discussion
    Last Post: 11-30-2005, 10:39 PM
  4. Replies: 5
    Last Post: 11-08-2005, 10:04 PM
  5. computer theft tracking - PC PhoneHome
    By Question in forum General MP3Car Discussion
    Last Post: 07-16-2003, 03:14 PM
