One time my work area in my room was messy and I triped over my ampie case and I was already having a bad day so I kicked my bed in rage and hurt my foot.
I had a toolbox fall directly onto my head from the very top shelf in my garage, maybe 10 feet up. I was incredibly lucky, the toolbox managed to hit my head facing absolutely perfectly straight forward and contacting directly in the center. So basically I dented the toolbox with my head and was stunned. Had the corner of the toolbox been forward, I might have had some severe injuries, sharp corner plus no weight distribution is not fun.
Whenever I do some work on my cars, no blood, job isn't finish.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
Cut my thumb down to the bone with a box cutter.....remember to
always cut away from yourself
"A rose by any other name is still a flower"
was shocked by the car's electrical system when my brother cranked the engine when i was twisting two cables together so i could solder them...
DAMN I FLEW!
but the worst was having a capacitor (car audio) Blow up in my face when my Opus Shorted out
For Bootscreens click Here
Drilled one of my fingers when moding CarPC case.
Also I cut the middle finger of my left hand with a razor blade (left it in the carpet floor and when using tools to take the seat out I applied to much pressure to the Wrench, inserted the whole blade in my finger **you can see the bone and all**) the night before of the florida meet so no time for stitches just some band aids and finger splint.
Thanatos.
Damn - whats with all the finger cuts,
I have got stabbed in the crotch with a screw driver, only went in
to my leg just a little, just missed my nuts buy a hair,
got a good shock and skin burn from a LCD inverter, soldering iron
burns, peeled the skin off my knuckle when I got my finger to close
to the alternator fan and belt, another time the belt came off and
slapped me - my mom used to hit me harder, drilled into my
finger 2 or 3 times, I use sheet rock screws a lot, they seam to go
in to sheet metal easy and I have a lot of them, drilled one into my
finger, I sprayed under coat under my car - with spray cans, got a
drop in my eyes, then burnt my hand on the tail pipe trying to get out
from under the car, etc etc etc, lots of small things
I lost my legs writing Digimoto.
Unfortunately I had to make something up because, as a geek, I haven't had much opportunity to do any real damage.
Joel Konecny
Digimoto OBDII Diagnostics
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
