Results 1 to 5 of 5
Thread: laptop display solution
    Jun 2001
    Washington State
    I am looking for one such solution. I recently bought a laptop and I love it, the only thing is that the srceen could be a little bit brighter. I have checked settings and I also don't think there are any external knobs or adjustments.
    The comp runs win 2000 and in looking at display properties/advanced/colormanagement/add,
    There are a bunch of color setting options. Will these do what I am looking for, or am I way off base here.
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    To make the screen brighter, you need a brighter backlight or a different screen. There isn't much you can do software wise.
    Jun 2001
    Washington State
    What kind of trouble will I have to go through to change out the backlight. And if I do that would it work, or is this something I best not start messing with.
    Thanks arby
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    On my lcd, you slide out the old one, and slide in a new one. It just depends on how much you have to take apart the laptop to get to the lcd.
    Also, you don't want to get too much brighter, because a brighter one will put additional load on the inverter, and produce more heat
    Jun 2001
    Washington State
    so in conclusion.....you think that the standard compaq armada m700 screen should be just fine? I seem to be getting used to it, I had just expected it to look more like other laptops I have seen.
