Results 1 to 10 of 11
Thread: amp +smoke = bad USUALLY
    pcman_cortina
    Guest
    ok get this
    i moved my amp onto the sub box in my boot and as im wiring it back up i managed to short the positive to the amp body i get a nice spark then smoke lots of smoke im almost crying at this stage the amps only like 3 weeks old and cost me 400 bux
    anyway i finish wiring it up cause i gotta put it back in anyway i then turn the ignition on expecting the amp to explode(taking me with it ) and the head deck turns on the cd starts playing and the amps working properly
    i go to the boot and the amps on no smoke no nothing
    i then kiss my amp and thank god or whoever saved my amp
    just had to let someone know
    cheers
    pcman
    Apr 2001
    Here, There, Everywhere
    Re: amp +smoke = bad USUALLY
    I usually give all my equipment hugs in that situation
    good stuff...
    Project - GAME OVER :(
    Jan 2001
    Adelaide, SA, Australia
    I've had a similar experience with my amp. Screwing the positive lead back on to it (for some reason i didn't disconnect the fuse, stoopid) and the screwdriver earthed out on the side of the amp chasis (a very nice ground). Lots of sparks, no smoke from the amp though. Still worked fine and dandy. mmmm 50rms x 4 I'm not a heavy bass listener, so that is quiet enough for now...
    http://www.mp3vl.tk Plans and progress on my install - (Updated 28 June 02)
    Australian mp3car Portal
    mp3car related links Check them out / Add some
    mp3car FAQ - RTFF
    [########==]80% Assembling
    -=Current Progress: Working Sproggy supply, building box.=-
    Live and Kickin'
    Arby's Avatar
    Dec 2000
    Houston
    I wan't paying attention when I was wiring mine up for a test, and switched the +12 and ground.
    Luckily, I just blew a fuse.
    Jul 2002
    smoke sucks
    pcman_cortina
    Guest
    yes it sux big time
    i like that sub box
    cheers
    pcman
    Maximum Bitrate albysure's Avatar
    Dec 2000
    pittsfield, ma.
    the sparks you saw were the caps in the amps charging up for the first time. you will always get some kind of spark from a large amp.
    Jul 2002
    Originally posted by pcman_cortina
    yes it sux big time
    i like that sub box
    cheers
    pcman
    FLAC MP3DUB's Avatar
    Jan 2002
    Chicagoland, IL
    As long as its not the magic blue smoke that makes the electronics work, then its all good . Glad to hear it still works, and is your avatar the "Proof that Girls are Evil" proof?
    -Nick
    _____________________________
    Monthly MP3Car Chicago Meets
    www.mp3vw.com Last updated: 07/07/2008
    pcman_cortina
    Guest
